jethro wrote:
so GT mowog, I won`t be able to change over completely to say splitfire gauges !!!!
Geoff
I didn't realise from your first post that you wanted something custom !
Yes, you could put spitfire gauges in, however the Air Speed Gauge will need significant re-calibration and you won't have to worry about screw on or clip on speed cables.
You'll also need a different distributor with a mechanical tacho take off!
It shouldn't be too difficult to put different gauges in. If they are non-smiths ones, you'll have to (preferably) get matching senders for fuel and temp, but that's not a 'show stopper'. I would think it more difficult to tastefully mount them actually.
<EDIT> for an oil presure gauge, there is presently a switch in the block near the distributor. You can either swap that for a gauge sender, or put a tee in so you can have both. Not a big deal.
