mini Traveller wood kits https://www.ausmini.com/forums/viewtopic.php?f=2&t=61754 |
Page 1 of 2 |
Author: | swiftden [ Sun Mar 14, 2010 10:40 am ] |
Post subject: | mini Traveller wood kits |
This is a question for those that have purchased a wood kit with the way the dollar is i am going to order one I have been quoted from various companies and just wondering about quality and fit etc All have been about the same price Mini Spares M-Machine Think these are both made by m-machine Forwoodies any one had any experience with them i know some have got the kits from forwoodies which to me so far sounds good since that is what the specialise in is wood kits for travellers and morriss minors etc regards allan |
Author: | swiftden [ Mon Mar 15, 2010 9:31 pm ] |
Just for info i got quoted the following so far Postage is to Lameroo SA. Mini spares Kit £498.40. + post £159.29. Forwoodies Kit £495.00. Post is approximately £120.00 I know two people who have got their kits from forwoodies . think i might go down that path ? |
Author: | Fat Boy Dave [ Fri Mar 11, 2011 10:01 am ] |
Holly thread revival Batman! ![]() So how did you go in the end? |
Author: | swiftden [ Fri Mar 11, 2011 11:52 am ] |
I ordered the wood kit from forwoodies and got it pretty quickly . Very good to deal with. Have had it in the shed for quite some time now. i have not assembled it but the quality looks good. |
Author: | Fat Boy Dave [ Fri Mar 11, 2011 11:58 am ] |
Noob traveller question, how do you fasten the wood panels on? Is it with these through the panels: ![]() What stops moisture getting trapped between the wood and the panel? Thanks. Wondering if I make my Van more of a Traveller replica. |
Author: | AWOODY [ Fri Mar 11, 2011 1:36 pm ] |
There is also a very good wood kit being made in America if you go through th minimania web site on their forum and ask where they will tell you . Those that have ordered it have been very pleased , all cnc engineered and all that very competetive price from memory as well |
Author: | Fat Boy Dave [ Fri Mar 11, 2011 1:49 pm ] |
That Minimania was one of the first websites I happened when searching for Traveller stuff and put the thought in my head. Ta. |
Author: | Fat Boy Dave [ Fri Mar 11, 2011 2:19 pm ] |
Not cheap though ![]() http://www.minimania.com/web/Item/WOOD/InvDetail.cfm |
Author: | Timbo [ Fri Mar 11, 2011 2:54 pm ] |
Fat Boy Dave wrote: What stops moisture getting trapped between the wood and the panel? There's meant to be a bead of mastic (a black rubbery sealant that stays a bit soft) around all the edges of the wood. One of the UK companies (somerford) sells something else, I think its like a thin double sided sticky tape that does the same job. They reckon its better. Tim |
Author: | bnicho [ Fri Mar 11, 2011 3:27 pm ] |
Timbo wrote: Fat Boy Dave wrote: What stops moisture getting trapped between the wood and the panel? There's meant to be a bead of mastic (a black rubbery sealant that stays a bit soft) around all the edges of the wood. One of the UK companies (somerford) sells something else, I think its like a thin double sided sticky tape that does the same job. They reckon its better. Tim I was talking to the owner of a blue Traveller at Wakefield about this. He bought the Somerford stuff and reckons it was just single sided foam rubber which looked the same as you can buy at Clark Rubber. It stuck to the wood before fitting and it did look neat. Personally I'd rather use Mastic I think. Messy to apply, but it would be very effective in keeping the water from getting between the wood and metal. Now, if someone just buys my Corona Coupe, then I can get started on it. ![]() |
Author: | Timbo [ Fri Mar 11, 2011 4:01 pm ] |
There's a massive range of sika products designed for bonding and sealing wood to metal etc. I reckon I'll use one of them, messy but very high quality. Tim |
Author: | AWOODY [ Sat Mar 12, 2011 1:50 pm ] |
I would also paint several coats of marine polyurathane on the wood before putting it on the car , I put one coat on the outside of my previous woody and it worked really well, however some people don't like the shiney look . |
Author: | GT mowog [ Sat Mar 12, 2011 2:09 pm ] |
How do you guys get on, with repspect to Quarantine, importing wood? I am unsure either way, but might pay to check http://www.daff.gov.au/aqis/travel/ente ... /cant-take |
Author: | Morris 1100 [ Sat Mar 12, 2011 2:24 pm ] |
I can't see any problem. |
Author: | swiftden [ Sat Mar 12, 2011 5:42 pm ] |
I never had a problem. Got through customs fine. They did open it to look but repacked it well and forwarded with no problems. No duty paid either. |
