Pic request: remote change gearbox
https://www.ausmini.com/forums/viewtopic.php?f=2&t=61895
Page 1 of 2
Author:  Asphalt [ Fri Mar 19, 2010 10:44 pm ]
Post subject:  Pic request: remote change gearbox
Hi!
Does anybody have a few pics of a remote gearboxe's shifter linkages? How they connect in & outside the gearbox?
I want to change from rod- to remote. But the gearbox I got is fully stripped - and it's my first. :)
Thanks!
Jan
Author:  TheMiniMan [ Fri Mar 19, 2010 10:51 pm ]
Ahhh,,,, virgin remote stick shifter hey???
that`ll teach you for not selling me those wider momos :-)
i have pics here in my books but havn`t got a scanner & my ph-camera-ph-thing is crap at taking pics,,, or maybe i`m crap at taking pics :-)
morris1100 (or someone like him) will help you tho i`m sure
it`s just shafts & knuckles.... oh that`s sounds quite kinky done-it???
Author:  blue_deluxe [ Fri Mar 19, 2010 11:20 pm ]
I can get a few pics, ive got a remote gearbox ready to bolt the diff on and drop into the car. or did you need the internal bits?
Author:  blue_deluxe [ Sat Mar 20, 2010 10:40 pm ]
Not sure how useful these are, iphones have terrible cameras it turns out.
The last 2 pictures are of the diff housing and it shows the face where the remote extension bolts on.
If you need any more external pics the engine wont be in for another week ish.
Author:  Asphalt [ Sun Mar 21, 2010 1:34 am ]
Thanks! :) Yes, that helps!
I'll post pics of mine after assembly, see if I put it right.
Jan
Author:  Morris 1100 [ Sun Mar 21, 2010 12:28 pm ]
Here is a couple of photos from the 4-syncro box that Dr Mini just put together for me... (note, it has a Morris 1100 diff housing)
Author:  TheMiniMan [ Sun Mar 21, 2010 3:27 pm ]
oh ,,, looks like you`re one spline out on the male knuckle
Author:  GT mowog [ Sun Mar 21, 2010 3:38 pm ]
Jee, that would be hard to do that cool trick with a rod shift, doesn't have enough linkages to wrong.......
It's also hard to strip them spines err...splines on a rod shift............
Author:  Morris 1100 [ Sun Mar 21, 2010 3:46 pm ]
Nah, it was just the way the shift was sitting.
Author:  TheMiniMan [ Sun Mar 21, 2010 3:47 pm ]
ah,,, but then some un-initiated nong-nongs can easilly have the actualtio shaft arounf the wrong way & the alloy "Eye" inside the shifter won`t let the gearstick work properly
& the diff hosing bush can be a pain to change with the exhaust in the way
& the roll pins for the couplings wear out
& those alloy "eyes" inside the shifter are easy broken
& the gearshift seals leak badly (unless they have one of my "Fixzits") :-)
oh,,,ok,,, i like lightweight flywheels & qucikshifts fitted to rod changes,,, i can`t keep up the fassard any longer
BUT!!! & don`t like copper head gaskets tho,,, BK450s are the go :-) :-) :-)
so there!!! :-)
& i still owe you a beer or 3 :-) you paid me too much
Author:  Morris 1100 [ Sun Mar 21, 2010 3:47 pm ]
Oh look. Another attempted hijack from the usual suspect.
Author:  TheMiniMan [ Sun Mar 21, 2010 3:48 pm ]
sorry morri,,, it`s my fault,,, i`ve been baiting it
Author:  Morris 1100 [ Sun Mar 21, 2010 3:53 pm ]
It is not your fault that every gearbox thread ends up with one bloke chiming in with his view regardless of whet the problem is. We could be talking about Muncie gearboxes and he would still pipe up with his "the rod change is so much better" crap.
Just like very engine miss thread turns into a copper headgasket is best thread. :roll:
Author:  drmini in aust [ Sun Mar 21, 2010 3:58 pm ]
re the spline position on the male knuckle..
I tried to put it horizontal (ie 1 spline up) and the bolt won't go through.
So there. BMC tolerancing.:P
Author:  TheMiniMan [ Sun Mar 21, 2010 4:05 pm ]
hmmm,,, cause if it`s central on the lock-out leg downstairs (inside the box) & it`s angled upwards at the knuckles,,, then maybe it`s one spline out downstairs?
they normally sit middle-middle if you onkw what i mean (& of course you do)
just thought that maybe when the pics were taken that it was moved inbetween the different pics,,, OR ,,, it`s out one spline somehwere (top at make knuckle,,, or bottom inside the box)
never fear,,, if it works then cool,,, i just hate muckin with those crappy remote knuckles when the donk is in the car
they``re the best shifting from 2nd to 3rd tho ey??? ;-) :-) :-) Way better than those crappy rod-changes :-) :-) :-)
