It is currently Sat Aug 09, 2025 2:50 am
 Post subject: Seat Replacements
PostPosted: Sat Mar 20, 2010 9:58 pm
Maybe this should be in modifications but i'll start it here and see what happens.
I'd like to compile a list of all the different other model seats people have in their minis.
I've heard of MX5 and Hyundai Getz, but i reckon we should post a list and pictures of the seats and peoples seat mounts
anyone care to share?
PostPosted: Sat Mar 20, 2010 10:34 pm
There have been a few threads on this, and there is such a thread as you propose on the UK mini forum (theminiforum.com)
You're so square
Baby I don't care
PostPosted: Sun Mar 21, 2010 8:01 am
It'd be good to have a clear list showing what fits well...rather than lots of small threads. Here's a few I found if you wanted to get infor from them:
A thread about engineer's cert. for fitting aftermarket seats
http://www.ausmini.com/forums/viewtopic.php?p=720893
adamstuart's thread
http://www.ausmini.com/forums/viewtopic.php?p=709765
Apparently Ford Festiva seats fit
http://www.ausmini.com/forums/viewtopic.php?p=671887
as mentioned, Hyundai Getz seats
http://www.ausmini.com/forums/viewtopic.php?p=662316
I'm putting 1990 Mazda 626 seats in mine, using the same mounts/holes as late leyland seats (on top of cross member) and some brackets. Not in yet, but i'll upload pics when they're in.
good luck with the list :)
Saxon Green 850: http://www.ausmini.com/forums/viewtopic.php?t=62641
Nightfire Red 850: http://www.ausmini.com/forums/viewtopic.php?t=66555
PostPosted: Mon Mar 22, 2010 11:30 am
Citroen BX 16-Valve front seats.
Comfortable with adjustable bolsters so you can have a cruising seat and a race seat all in one.
Mister White Keys
"He who has the most toys, Wins"
1963 Austin Countryman Woody
1964 Morris 850 Van
1967 Austin Countryman
1975 Range Rover 2 Door
2004 Subaru Forester XT
2015 Potts Teardrop Camper
RIP 1990 Citroen BX 16Valve
PostPosted: Wed Mar 24, 2010 12:38 pm
I have fitted a pair of Mazda MX5 seats. You need to swap them left/right so that the adjustment controls are near the handbrake otherwise they foul the door pockets.
Suzuki Swift Cino / Barina seats fit, I sold a pair to a mini owner.
Suzuki Swift Gti seats also fit and are very comfortable & sporty.
I measured a set of the new Swift seats last night & they are 20mm narrower than the Gti seats, so should fit well. If anyone in Perth wants some, I know where you can pick up a couple of virtually new sets for $300 a pair.
PostPosted: Wed Mar 24, 2010 8:39 pm
my biggest problem with the seating in my mini is my head in the roof.
i'm only 6 ft tall so i'm looking to drop the seats down as far as possible.
by my rough tests, putting the seats on the floor behind the crossmember as some people do will be too far for my arms to reach the wheel so i'm looking at mounting a seat at a similar front/rear location as original, but mounted flat on the crossmember not 2 inches above it.
to do so i need the seat adjustments on the sides, not the front, does this lessen my options?
