It is currently Sat Aug 09, 2025 7:38 pm
 Post subject: Grease Nipples
PostPosted: Mon Mar 22, 2010 3:56 pm
Where abouts are all the grease nipples located? cheers
1977 LEYLAND MINI SUNSHINE 'S'
PostPosted: Mon Mar 22, 2010 4:03 pm
6 at the front
- 1 On the top control arm (1 each side)
- top ball joint (1 each side)
- bottom ball joint (1 each side)
2 at the rear
- on the rear trailing arm just in front of the rear wheels on each side
If remote shift there is also one down the back of the motor there...
PostPosted: Mon Mar 22, 2010 6:27 pm
also applies to 850 magic wand and pov pack puddin' stirrer shift models... and usually/sometimes, there's another at the back of the remote shift housing too.
PostPosted: Mon Mar 22, 2010 7:09 pm
Thanks for that info. Can you buy flexi hose for grease guns?
PostPosted: Mon Mar 22, 2010 7:30 pm
yes
PostPosted: Mon Mar 22, 2010 7:44 pm
Got one from AutoPro.....about $15...I think?
