Broke wheel stud-nut. https://www.ausmini.com/forums/viewtopic.php?f=2&t=61946 |
Author: | NG [ Mon Mar 22, 2010 7:28 pm ] |
Post subject: | Broke wheel stud-nut. |
he lads. my superman strength, lol i broke a wheel stud on my 8.4 disk brakes. i have a new one on order. is there a how to? i have never replaced one, im not sue what to do, is there any tools i need? can it be done on the car? or do i need to take the whole disk brake out to do it. thanks. |
Author: | GT mowog [ Mon Mar 22, 2010 7:33 pm ] |
You'll need to take the drive flange off the disc. There are several different studs so I trust that you have ordered the correct one. 40ft/lb no more. |
Author: | Austin850 [ Mon Mar 22, 2010 7:33 pm ] |
I did exactly the same thing on my 7.5" brakes a few weeks ago. If 8.4" brakes are setup the same as the little ones then the studs are a piece of cake to replace. I just gently drifted the remains of the old stud out using a centre punch and put the new one in from the back. I then used a standard wheel nut to pull the new one all the way in and Bob's your uncle. It's probably not a bad idea to put a small spray of WD40 on each of the studs before replacing the nuts. Cheers, Simon edit - I just read GT Mowog's post. I didn't need to take the flange off mine, so maybe the bigger disks are different. |
Author: | TheMiniMan [ Mon Mar 22, 2010 7:35 pm ] |
with 8.4 discs, you need to remove the road wheel, loosen the 3 bolts through the drive flange into the dic, take the big center nut off,,, & then tak the caliper off (2bolts) but you can leave the hose attached & rest the caliper onto a tin or block of some sort so you don`t stretch the hose & then tak out the 4 bolts holding the flange to the rotor, take the flange to a vise & smack it out with a punch,,, smack the new one back in & whack it all back together i have done it on the car by removing the caliper & taking the 4 drive flange bolts out & pushing the disc back away from the flange & with a bit of a fiddle & fart-arse & swearing you can get the old one out leaving the big center nut on so the flange is still attached to the CV , butt it`s a right pain in the butt take the flange out & do it on the bench/vise , it`s much easier cooper"S" ones are way easier,,,you can just smack em out & pry the new one back in ![]() |
Author: | Austin850 [ Mon Mar 22, 2010 7:37 pm ] |
Oh well. Looks like another good reason to go for 7.5" disks ![]() |
Author: | NG [ Mon Mar 22, 2010 7:40 pm ] |
GT mowog wrote: You'll need to take the drive flange off the disc. There are several different studs so I trust that you have ordered the correct one.
40ft/lb no more. i ordered from lindsay, i would assume rover disk brakes would be all the same? what is the difference. i know 40ft i was told so many times :p my bad. thanks matt, bit of fuffing around then! bah. |
Author: | TheMiniMan [ Mon Mar 22, 2010 7:48 pm ] |
Nah ,,,it`s pretty easy & quick mate,,, you`ll need an 1"&5/16ths socket for the big center(CV) nut tho,,, or a motha shifter a 9/16ths spanner (or socket) for the caliper bolts ,,, easy & a 9/16ths socket & breaker bar for the drive flange bolts,,,again pretty easy & yes max tightness on both the drive flange bolts & the wheel nuts is actually 42lbs,,, but 40 is fine too ![]() I """ALWAYS"""" use a torque wrench on "ALL" wheel nuts !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! |
Author: | NG [ Mon Mar 22, 2010 7:51 pm ] |
TheMiniMan wrote: Nah ,,,it`s pretty easy & quick mate,,,
you`ll need an 1"&5/16ths socket for the big center(CV) nut tho,,, or a motha shifter a 9/16ths spanner (or socket) for the caliper bolts ,,, easy & a 9/16ths socket & breaker bar for the drive flange bolts,,,again pretty easy & yes max tightness on both the drive flange bolts & the wheel nuts is actually 42lbs,,, but 40 is fine too ![]() I """ALWAYS"""" use a torque wrench on "ALL" wheel nuts !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! yep i have been told this many times!!! i think it's time i buy one. |
Author: | TheMiniMan [ Mon Mar 22, 2010 7:55 pm ] |
ick,,, funny as this may sound,,, it`s probably more of a "Past-fatigue" that`s caused it,,, tyre shops are renowned for using big impact rattle guns on wheel nuts & most of em dont realise that the P!$$y litlle mini nuts need P!$$y little torque,,,so their big phat rattle guns just stretch the sh!t outa them then you change a wheel & snappo,,, that`s the usual scinerio anyways ![]() |
Author: | NAV [ Mon Mar 22, 2010 8:27 pm ] |
What Matt said, plus i like to make sure the threads are nice and clean too, that way you know how tight they really are |
Author: | TheMiniMan [ Mon Mar 22, 2010 8:31 pm ] |
& add a little "dash" of copper-coat to the threads before fitting the nuts,,, makes em all nice next time ![]() |
Author: | Trog [ Tue Mar 23, 2010 6:52 am ] |
Just a thought but if you broke one and you are going to the effort of removing the flange why not replace all 4... If ones broken due to abuse/fatigue/age etc. then its not unreasonable to assume the others may be weak/compromised too? Personally I would go the whole hog and replace all studs on both sides to do the job properly and be sure... But I am a belts and braces kind of guy... |
Author: | AEG163job [ Tue Mar 23, 2010 10:58 pm ] |
I agree. The remaining studs are probably approaching their 45th anniversary and close to retirement age. Lash out & replace the lot. |
