door hinges
https://www.ausmini.com/forums/viewtopic.php?f=2&t=6201
Author:  christo [ Fri Apr 08, 2005 7:38 pm ]
Post subject:  door hinges
Gday
About to put back the door hinges, which way do the studs go? anything to look out for ? .. any web sites with a how to on this topic ?..
Christo
Author:  poeee [ Fri Apr 08, 2005 7:40 pm ]
A tip when you do them...
Put the hinges on the car first, not on the door. Alot easyer to put on or take off the hinges with the door not attached!
Author:  9YaTaH [ Fri Apr 08, 2005 8:49 pm ]
Post subject:  handed
all four are handed?....that is..they can only go on in one place...
Author:  drmini in aust [ Fri Apr 08, 2005 8:58 pm ]
The top pair are wider at the top, the bottom pair are wider at the bottom, but less so. 8)
There are code letters on the back of each hinge, but I can't remember what they are.. :?
Author:  J_A_M [ Fri Apr 08, 2005 9:18 pm ]
RU = Right Upper
LU = Left Upper
LL = Left Lower
RL = Right Lower
Author:  drmini in aust [ Sat Apr 09, 2005 10:12 pm ]
I beg to differ. Take the door off the hinges first, yes- but when putting back on, the top hinge on the door is a bit of a bugger to get the rear bolt & tapered washer in.
Easier to bolt the hinges to the door first, then put the lot to the car and slip the front nuts on.
BTW repinning door hinges was pretty easy, but I had to turn up new bronze bushes 9mm OD, as the ones in the kit (5/16" OD) were smaller than the hole worn in the hinges... :shock:
Author:  drmini in aust [ Sun Apr 10, 2005 7:40 pm ]
Got mine (RH) back on Ha-Ha this arvo, geez it's different not having slack hinges! :lol: I nearly got pinged for it last year..
Down for a pink slip tomorrow... :wink:
Author:  Mike [ Mon Apr 11, 2005 7:19 am ]
I've got the bloody chrome hinges (previous owner) and they are getting a bit soggy, but I cant punch the pins out - (theyre covered in chrome). Anyone dealt with chrome hinges before?
Author:  drmini in aust [ Mon Apr 11, 2005 7:32 am ]
Bring 'em up (off the car), and I'll do them for you.
Don't try to punch them out on the car... :cry:
BTW.. the pins are fitted from the top and the top end of pin is knurled, so they have to be knocked out from the bottom. :wink:
