Upgrading to pot joints
https://www.ausmini.com/forums/viewtopic.php?f=2&t=62015
Author:  jester99 [ Thu Mar 25, 2010 11:43 pm ]
Post subject:  Upgrading to pot joints
I have a remote gearbox with the rubber uni joints.
if i upgrade to pot joints can i use the shafts i already have or do i need shafts aswell?
can i just buy 2 x pot joints and utilise the current shafts that i have?
the origonal rubber type output shaft flanges are badly worn on the shafts as you can see below. i am hoping i may be able to just buy the pot joints and it will all bolt up using what i have.
Jason 8)
Author:  TheMiniMan [ Thu Mar 25, 2010 11:58 pm ]
you need to swap the "Inner" axles,,, the ones that come through the diff side covers from the inside
to do that--> the engine needs to come out of the car & then it`s fairly straight forward procedure
& also swap the outer axles too
if you need all the bits , then i have them here,,,inc 2x new final drive seals,,, you should fit new seals in while you`re there
Matt
Murarrie
0407 135656
Author:  blue_deluxe [ Fri Mar 26, 2010 11:47 am ]
I'm doing this job atm, it's not to bad. only issues i've had were that I upgraded to a 4 pin diff, so bearings were a hassle.
If you want any pics of bits just say.
