It is currently Sun Aug 17, 2025 11:37 am
 Post subject: Upgrading to pot joints
PostPosted: Thu Mar 25, 2010 11:43 pm
I have a remote gearbox with the rubber uni joints.
if i upgrade to pot joints can i use the shafts i already have or do i need shafts aswell?
can i just buy 2 x pot joints and utilise the current shafts that i have?
the origonal rubber type output shaft flanges are badly worn on the shafts as you can see below. i am hoping i may be able to just buy the pot joints and it will all bolt up using what i have.
Jason 8)
PostPosted: Thu Mar 25, 2010 11:58 pm
you need to swap the "Inner" axles,,, the ones that come through the diff side covers from the inside
to do that--> the engine needs to come out of the car & then it`s fairly straight forward procedure
& also swap the outer axles too
if you need all the bits , then i have them here,,,inc 2x new final drive seals,,, you should fit new seals in while you`re there
Matt
Murarrie
0407 135656
PostPosted: Fri Mar 26, 2010 11:47 am
I'm doing this job atm, it's not to bad. only issues i've had were that I upgraded to a 4 pin diff, so bearings were a hassle.
If you want any pics of bits just say.
Simplify and add lightness
Users browsing this forum: Bing [Bot] and 366 guests
