It is currently Tue Aug 05, 2025 11:30 am
 Post subject: Silicon - Gasket
PostPosted: Sat Mar 27, 2010 11:56 am
as the motor is out due to the broken crank its time to fix a few other things also. The Perry LCB actually has a flang gasket. I didn't think it would be easy to find one which fitted and as expected no luck. One exhaust place said to use plain silicon :shock: as they use it on most cars. I didn't like the sound of silicon. But while at Burson i noticed they a heat resistant Copper Silicon so Ill see how it goes.
But what are your experiences with just silicon for exhaust gaskets
PostPosted: Sat Mar 27, 2010 12:20 pm
Silicone sealant is good for about 400° or so.
But where that flange is (bottom of the 2 downpipes) it'll get to near red heat.
It might survive... but I doubt it. Try it and see.
I reckon you are going to need a flange gasket. Or, coating the 2 flanges with muffler putty then bolting together might work.
PostPosted: Sat Mar 27, 2010 4:40 pm
We used roof and gutter to seal pretty much any gap on our fear car, it did backfire though and got sucked through the inlet and stopped a spark plug. then it killed the lambda sensor too. so it takes he heat bt destroys electrics.
Simplify and add lightness
PostPosted: Sat Mar 27, 2010 4:59 pm
Tomboss Breweros
I like the loctite hi temp red silicone for jobs like this.
If the flanges are really flat it should be fine. I used it to seal the combustion chamber to the turbine housing on my turbojet engine, it ran red hot and held up fine.
kimini wrote:
Jimmyinamini wrote:
PostPosted: Sat Mar 27, 2010 6:50 pm
I usually use Maniseal on exhaust joints.
PostPosted: Sat Mar 27, 2010 6:57 pm
For those wondering, Gaf's manifold is a Perry (or similar) LCB that some enterprising individual has cut the downpipes at the slip joint, and fitted mating double flanges... then bolted it together.
It had a gasket, but it's knackered.
PostPosted: Sat Mar 27, 2010 6:58 pm
Most exhaust places carry the stock flange gaskets.
PostPosted: Sat Mar 27, 2010 8:32 pm
Yep interesting one this one, I even had to show Greg @ Karcraft as he had never seen a Perry with a flang which fits under the back brace of the front subframe. Ill take a pic tomorrow for you all. I tried 5 different exhaust place in total an came up with zip and two offered to find and order in but were unable to get a match close to it. So I'm going to test out Permatex Ultra copper High Temp RTV Silicone. It's not cheap at $20 for a 85G tube but ill also use it further down the system to see how it goes with the temp
PostPosted: Sat Jul 17, 2010 9:01 pm
Some one :wink: did remind me about this today. Considering I was looking for the gasket for the flange. I reluctantly went with this high temp silicon. Todate I could not complain and nor has my wife.
Must admit I really clean the surfaces and layed it on thick then bolt it up..Perfect and I would recommend it
PostPosted: Sun Jul 18, 2010 7:51 am
Glad to hear that you have had such good success with what could have been a headache - in more way than one!
 Post subject: silicon gasket
PostPosted: Sun Jul 18, 2010 9:59 am
we used silicon on both racecars, never had any problems.
One was a 350 chev , the other was a rotary. Both speedway super sedans running at max revs. the rx7s exhaust glowed from the extractor back to the muffler.
cheap work is not good, good work is not cheap
Users browsing this forum: Bing [Bot] and 80 guests
