It is currently Mon Jul 21, 2025 3:14 pm
PostPosted: Sun Mar 28, 2010 11:55 am
Ms Plum runs an 1100S engine exactly as it was lifted from it's orginal home and complete with 4.2 diff, whilst this makes her go like a cut cat to about 80kph, with 10" wheels and 145 tyres she does scream and wheel spin can be a bit of a problem.
I want to keep the 10" wheels and the 145's as she's a bit of a sleeper so no flares allowed, therefore the question is what diff ratio would people recommend I use?
Off the line speed is nice but given where I live I do a fair bit of my toy driving at 80 or 100kph so having a reasonable level of rpm at cruising is probably most important.
Ms Plum runs Cooper S discs already and I'm wondering if I should perhaps look at changing from rubber uni's while the diff is being done, what's the general recommendation atm.... steel uni's or go for pot joints?
Thoughts?
'62 Morris 850 (Marion)
'69 Vanden Plas Princess 1300
'71 Wolseley 1300
'74 Austin 1300 Countryman
'94 XJ6 Sport 3.2
'04 Rover 75 CDTi
PostPosted: Sun Mar 28, 2010 12:35 pm
3.44:1 works nice and is easy to find S/H. Most rodchange boxes here used them, apart from the Cooper S.
A 3.1 or 3.2 would be good but were never sold here, you would need to get one her off a Rover front cut (maybe), or import it from UK.
Forget steel unis, fit pot joints whilst the diff is out. More reliable and less power loss.:wink:
PostPosted: Sun Mar 28, 2010 2:53 pm
+1 on the 3.44. Still zippy but not revving its tits off on the highway.
Pot joints get a thumbs up from me but rubber unis can be fine if they're kept oil free and the rest of the associated setup is in good nick.
Jacob
PostPosted: Sun Mar 28, 2010 3:14 pm
Rubber joints available currently are crap compared to the originals.
I'd go the pot joints...
PostPosted: Sun Mar 28, 2010 6:37 pm
Thanks guys, Doc did I read recently that the Rover diffs are physically bigger and don't fit in the standard housing without maching? Would this apply to Morris 1100 diff housings too?
'71 Wolseley 1300
'94 XJ6 Sport 3.2
'04 Rover 75 CDTi
PostPosted: Sun Mar 28, 2010 7:27 pm
No it's the AUTOMATIC CW/Ps that won't fit into a manual box. They are bigger.
A Rover diff is same as the old ones, except:
1. The copper thrust washers have tabs into the diff centre so they don't spin like the old A series ones.
2. The crownwheel & pinion tooth form is a different angle. But they do fit in old boxes fine, as a SET.
[edit] on diff ratios 3.1 and taller (2.95 etc) in old boxes, the 3rd motion shaft bearing retainer often needs machining out a couple of mm to clear the bigger pinion. 5 minute job in a lathe.
Yes this includes the 1100 box.
