It is currently Fri Jul 18, 2025 5:16 pm
PostPosted: Sun Mar 28, 2010 3:10 pm
so i have just purchased both a clutch and brake master cylinder. they are the new type with round plastic tank that minisport in Adelaide sells. however, they look pretty much identical! i understand that the brake has a non return valve or something of the sort in it, where as the clutch doesn't (or visa versa). the bases are a little bit different, one has a larger base then the other. does anyone know how i can tell which is which?
thanks!
PostPosted: Sun Mar 28, 2010 3:27 pm
Tomboss Breweros
Gently poke a thin bit of wire in the little hole at the top, if it stops it's the brake master, if it goes straight in is the clutch :wink:
kimini wrote:
Jimmyinamini wrote:
