brake and clutch master cylinders https://www.ausmini.com/forums/viewtopic.php?f=2&t=62063 |
Author: | davestar62 [ Sun Mar 28, 2010 3:10 pm ] |
Post subject: | brake and clutch master cylinders |
so i have just purchased both a clutch and brake master cylinder. they are the new type with round plastic tank that minisport in Adelaide sells. however, they look pretty much identical! i understand that the brake has a non return valve or something of the sort in it, where as the clutch doesn't (or visa versa). the bases are a little bit different, one has a larger base then the other. does anyone know how i can tell which is which? thanks! |
Author: | Tombo [ Sun Mar 28, 2010 3:27 pm ] |
Gently poke a thin bit of wire in the little hole at the top, if it stops it's the brake master, if it goes straight in is the clutch ![]() |
