Black caps on Minisport Hi Lo's https://www.ausmini.com/forums/viewtopic.php?f=2&t=62091 |
Author: | mtsmini [ Mon Mar 29, 2010 6:23 pm ] |
Post subject: | Black caps on Minisport Hi Lo's |
If you have bought Hi Lo's from Minisport in the UK: they come with a black plastic cap on the end of the cone. Do I take this off or fit the hi lo with it? It fits with or without it in! ![]() |
Author: | simon k [ Mon Mar 29, 2010 7:38 pm ] |
pic? can't see the rubber cone mounting face of the hilo in the picture of them on the website ![]() you're not talking about this bit are you? if so, then yes, the cup stays on there - it's called a knuckle ![]() |
Author: | dodge [ Mon Mar 29, 2010 7:49 pm ] |
1/2 fill the cones with some good grease too stops corrosion over time |
Author: | Trog [ Mon Mar 29, 2010 8:52 pm ] |
Leave 'em on... They help to keep the threads from rusting up... |
Author: | mtsmini [ Mon Mar 29, 2010 11:11 pm ] |
Post subject: | Hi los |
It's not the knuckle I'm talking about - it's the other end that you can't see in the picture. Consensus seems to be leave them in as they help prevent water getting into the cone thereby preventing corrosion. Plus, grease absolutely everything! Thanks... ![]() |
Author: | mtsmini [ Wed Mar 31, 2010 4:23 pm ] |
For the record....Minisport say leave em on. Big night of greasing-up ahead - and then I might work on the subframe ![]() |
