It is currently Fri Aug 15, 2025 11:33 pm
What works best: One Piece moulded Windscreen Rubbers or Rubber cut off the roll
One Piece Moulded Windscreen Rubbers 90%  90%  [ 9 ]
Cut off the roll Windscreen Rubbers 10%  10%  [ 1 ]
Total votes : 10
 Post subject: W/screen rubbers
PostPosted: Tue Mar 30, 2010 12:12 pm
:? One piece or off the roll cut to size?
:idea: I guess if a pro does it, it shouldn't leak at all!
:?: Whos windscreen doesn't leak?
PostPosted: Tue Mar 30, 2010 1:53 pm
I can't see a pro reason for an off-the-roll rubber if single piece rubbers are available for the same money, but I have a single up front and a cut down at the rear and neither leak...
PostPosted: Tue Mar 30, 2010 7:04 pm
Would think the single piece would look better. Mine comes from a roll, and yes it does leak (when parked in the open).
I assume it always came in a roll; but if I can get it as one piece, i'd go for that instead.
1966 Morris Mini Deluxe
.... 4 bicycles and 3 screaming kids.
PostPosted: Tue Mar 30, 2010 7:39 pm
The `one piece' rubbers are made the same way (off a roll) then cut to length by the supplier and the ends glued.
I find they fit better in the corners, as by the time you fit them they are nearly the right shape.
But I have had rear 1 piece Mk1 rubbers that were cut too long, no way would they fit.
 Post subject: Rubbers...
PostPosted: Wed Mar 31, 2010 3:48 pm
I prefer the thin ones with the ridges...jesus wrong forum, delete, delete....
Regards,
Mike
"He who dies with the most toys wins."
Users browsing this forum: No registered users and 346 guests
