W/screen rubbers
https://www.ausmini.com/forums/viewtopic.php?f=2&t=62107
Author:  Benyni [ Tue Mar 30, 2010 12:12 pm ]
Post subject:  W/screen rubbers
:? One piece or off the roll cut to size?
:idea: I guess if a pro does it, it shouldn't leak at all!
:?: Whos windscreen doesn't leak?
Author:  Mick [ Tue Mar 30, 2010 1:53 pm ]
I can't see a pro reason for an off-the-roll rubber if single piece rubbers are available for the same money, but I have a single up front and a cut down at the rear and neither leak...
Author:  marc2131 [ Tue Mar 30, 2010 7:04 pm ]
Would think the single piece would look better. Mine comes from a roll, and yes it does leak (when parked in the open).
I assume it always came in a roll; but if I can get it as one piece, i'd go for that instead.
Author:  drmini in aust [ Tue Mar 30, 2010 7:39 pm ]
The `one piece' rubbers are made the same way (off a roll) then cut to length by the supplier and the ends glued.
I find they fit better in the corners, as by the time you fit them they are nearly the right shape.
But I have had rear 1 piece Mk1 rubbers that were cut too long, no way would they fit.
Author:  mtsmini [ Wed Mar 31, 2010 3:48 pm ]
Post subject:  Rubbers...
I prefer the thin ones with the ridges...jesus wrong forum, delete, delete....
