Smiths RPM Wiring RVI
https://www.ausmini.com/forums/viewtopic.php?f=2&t=62137
Author:  brett [ Wed Mar 31, 2010 3:20 pm ]
Post subject:  Smiths RPM Wiring RVI
Has anyone wired one of these up?? Whats the wiring diagram??
Cheers Brett
Author:  mini-mini [ Wed Mar 31, 2010 3:32 pm ]
This might help:
http://mk1-performance-conversions.co.uk/technical_electrical.htm
Author:  Angusdog [ Wed Mar 31, 2010 5:27 pm ]
Author:  brett [ Wed Mar 31, 2010 9:13 pm ]
kida looks like the same pice of wire that goes from the coil wraps around the distributer
thanks guys! :D
Author:  winabbey [ Thu Apr 01, 2010 8:31 pm ]
In case it isn't clear it's the pink diagram above and the dotted line means the wire between the coil and distributor has been removed. It's been replaced by a long white one that goes from the coil up to the tacho, looping through the plastic block, and then back to the distributor.
Apologies if that was already clear.
Author:  brett [ Thu Apr 01, 2010 8:49 pm ]
yeah thanks got it working!! :D Suprise Suprise I double checked with my auto electrican, finished it off at front of the shop during working hours! 8)
