Replacing drums https://www.ausmini.com/forums/viewtopic.php?f=2&t=6214 |
Author: | IwannaMini [ Sat Apr 09, 2005 10:16 am ] |
Post subject: | Replacing drums |
Guys and Girls is it possible to replace the drums without needing to bleed the brakes..? ie. Is it just a matter of removing the retaining screws and withdrawing the old drum and throwing on the new drum..? My front drums are oval rather than round. ![]() Also I am looking at getting the following replacement drums http://www.minispares.com/Product.aspx?pid=36485 |
Author: | hneil [ Sat Apr 09, 2005 10:23 am ] |
Believe it is that simple, EXCEPT you should adjust the brake shoes after the new drum is installed. |
Author: | mini_me [ Sat Apr 09, 2005 10:24 am ] |
Post subject: | replacing drums |
you can change the shoes without bleeding the brakes.you just need to adjust the shoes.actually changed the shoes on my daughters corolla yesterday felix |
Author: | Dylans Clubby [ Sat Apr 09, 2005 10:27 am ] |
you should be able to, the drums come on and off without having to take off the shoes and getting into the plumbing |
Author: | IwannaMini [ Sat Apr 09, 2005 10:30 am ] |
Post subject: | Re: replacing drums |
mini_me wrote: you can change the shoes without
bleeding the brakes.you just need to adjust the shoes.actually changed the shoes on my daughters corolla yesterday felix Hey Felix... shoes are pretty new... how about the drums. Can I replace them without touching any of the other components. I want it to be a "pull the drum off, put new drum on and adjust" affair. |
Author: | mini_me [ Sat Apr 09, 2005 10:36 am ] |
Post subject: | brakes |
sorry i misread your message. the drums will only take a couple of mins to change and then adjust the shoes. have you scored the old drums or are they oversize felix |
Author: | min13k [ Sun Apr 10, 2005 12:17 am ] |
depends if the drums are standard or o/s and wether the shoe's are standard or o/s makka |
Author: | IwannaMini [ Sun Apr 10, 2005 10:12 am ] |
Post subject: | Re: brakes |
mini_me wrote: have you scored the old drums or are they oversize
felix The front drums are warped from age and so are slightly oval. Under low speed normal driving its OK, but braking from 70km/h+ and the front end vibrates like mad. The shoes are oversized from memory of the last time I looked. |
Author: | 68matic [ Sun Apr 10, 2005 12:05 pm ] |
fluid -> pistons -> shoes -> drums slack the shoes remove drums replace drums tighten the shoes you dont touch the fluid or the pistons so no bleeding needed although bleeding brakes is easier than replaceing drums ![]() |
Author: | IwannaMini [ Sun Apr 10, 2005 4:46 pm ] |
all just been bled and new shoes put on. Just didnt have the drums to go on. Now that I know someone going to the UK for a week, someone is giving them a shopping list for Mini parts. : D |
Author: | min13k [ Sun Apr 10, 2005 4:50 pm ] |
wanna you need the correct shoes for the drum if you have o/s shoe's you will have a problem getting them in to a standard drum makka |
Author: | IwannaMini [ Sun Apr 10, 2005 4:56 pm ] |
Is there an oversized shoe drum ![]() |
Author: | min13k [ Sun Apr 10, 2005 5:06 pm ] |
when your drums get old and scored they take some of the metel of the face and at a certain point you need to run a thicker pad so it will still make contact if the shoe is to thick it just wont fit and i would not get the drum over sized if it is brand spankers makka |
Author: | IwannaMini [ Sun Apr 10, 2005 5:17 pm ] |
I see... So if this is the case, new shoes..?? I guess it cant hurt to get em all new eh..?? |
Author: | drmini in aust [ Sun Apr 10, 2005 8:00 pm ] |
When drums are worn the brake shops machine them bigger and supply thicker bonded shoes, radius ground to suit. Stock drums are 7.000". Standard oversizes are +1/32" and +1/16" diameter. ![]() |
