kaka wrote:
The other week I wrote in about my mini (remote change) not finding gears, crunches ,etc. I was advised about a worn clutch arm ball, plus some other good things to check . Anyway I finally changed the clutch arm and adjusted the clutch.
My mini is back changing gears no crunching or grinding. As this post was lost I forgot who gave me the free advice but am thanking you as you will know who you are. Was terrified it was my gearbox - ching ching
The slave cylinder did need a bleed as someone else advised.
Thanks again
Your welcome, glad it worked out.
