It is currently Sat Aug 09, 2025 11:27 am
PostPosted: Fri Apr 02, 2010 10:05 am
Does anyone know what the correct master cylinders were for a MK11 S ? Were they one particular brand or possibly a mixture of Lockheed or PBR.?
Thanks Colin.
PostPosted: Fri Apr 02, 2010 1:03 pm
What yr because 69's had the tin ones where as though the 71's had the plastic resovour ones?
i think somewhere in between ther was a combination of the two
PostPosted: Fri Apr 02, 2010 1:41 pm
I would bet that all the cars came off the line with Lockheed cylinders.
I am fairly sure that the PBRs were just sold as replacement parts.
PostPosted: Fri Apr 02, 2010 2:00 pm
i`m in agree-ance with Morris1100 on this one,
i`ve been told by some so-called "Experts" that PBRs were the factory fitted one somehwere in the middle of the MK2 range,,, but who can say for sure??? Maybe the factory ran out of cyls at one stage & sourced them locally , I`ll ask my dad (again) & see what he says,,, Probably him & John Shmidt would be the ones who would know for sure (if anyone would)
PostPosted: Fri Apr 02, 2010 2:06 pm
They were sourced locally. The Lockheeds were made at Belmore, Sydney. :wink:
John would know. :wink:
PostPosted: Fri Apr 02, 2010 3:08 pm
7/70 had cast iron lockheed upright plastic jobbies :D
PostPosted: Fri Apr 02, 2010 4:32 pm
My 71 clubby has lockheed ones
PostPosted: Fri Apr 02, 2010 4:33 pm
G'day people, yeah mine's a 6-70 with Lockheed .7 brake & .7 clutch master cylinders.
I've often seen threads where people have said that the clutch should be a .75 cyl. The reason i ask is that i scored a brand new PBR brake master cyl ( no: 15A1G stamped into the side of it ) complete, and i might use it on my car at some stage if & when mine decides to sh!t itself, even if it's not the right one it will still look the part.
Thanks Colin.
PostPosted: Fri Apr 02, 2010 4:55 pm
0.7s are a recipe for clutch drag problems.
0.75 moves more fluid, allows you more clutch pedal takeup height adjustment.
PostPosted: Fri Apr 02, 2010 5:06 pm
my 12/71 Gt has a lockheed and a PBR both are .7. I was told some cars came with 2x .7's but i think one of mine may have been replaced.
GT mowog also told me that the PBR's were replacement ones about a month ago
PostPosted: Fri Apr 02, 2010 7:14 pm
yeah for some reason most minis came with .7 clutch cyls,,, i hate em & always use .75 diam clutch cyls
i actually took one out of a customers mini today )Emma & Tims little Yellow brick) to fix it,,, well it was .7 diam & had the brake valve :-) altho it was also stuffed & needs a sleave too
typical tho
& yes obviously i`ll be replacing the hose & kitting the slave cyl as well,,,, it`s all about the "Package"
I think what has happened is that "Back in the day" there were soooo many replacment items made here in Aust that quite a lot of people thought that it must have been a factory item from the start,,, now "some" of them may very well have been from the factory,,, this is the part i`m un-sure of,,, either way , i doubt that anyone could say "For-Sure" that any particular cyl "Wasn`t" factory fitted,,,whether it be LookRead or PBR
