It is currently Fri Aug 08, 2025 7:58 am
 Post subject: can't find gears
PostPosted: Sat Apr 03, 2010 5:28 pm
The other week I wrote in about my mini (remote change) not finding gears, crunches ,etc. I was advised about a worn clutch arm ball, plus some other good things to check . Anyway I finally changed the clutch arm and adjusted the clutch.
My mini is back changing gears no crunching or grinding. As this post was lost I forgot who gave me the free advice but am thanking you as you will know who you are. Was terrified it was my gearbox - ching ching
The slave cylinder did need a bleed as someone else advised.
Thanks again
PostPosted: Sat Apr 03, 2010 5:46 pm
Great to hear you got it sorted. I read your post the other day before it disappeared.
Awesome you it going again, congrats, i know how you felt as my similar issues recently ended with engine out and a full rebuild.
8)
 Post subject: Re: can't find gears
PostPosted: Sat Apr 03, 2010 5:50 pm
Thanks again
Your welcome, glad it worked out.
