can't find gears https://www.ausmini.com/forums/viewtopic.php?f=2&t=62205 |
Author: | kaka [ Sat Apr 03, 2010 5:28 pm ] |
Post subject: | can't find gears |
The other week I wrote in about my mini (remote change) not finding gears, crunches ,etc. I was advised about a worn clutch arm ball, plus some other good things to check . Anyway I finally changed the clutch arm and adjusted the clutch. My mini is back changing gears no crunching or grinding. As this post was lost I forgot who gave me the free advice but am thanking you as you will know who you are. Was terrified it was my gearbox - ching ching The slave cylinder did need a bleed as someone else advised. Thanks again |
Author: | jester99 [ Sat Apr 03, 2010 5:46 pm ] |
Great to hear you got it sorted. I read your post the other day before it disappeared. Awesome you it going again, congrats, i know how you felt as my similar issues recently ended with engine out and a full rebuild. ![]() |
Author: | GT mowog [ Sat Apr 03, 2010 5:50 pm ] |
Post subject: | Re: can't find gears |
kaka wrote: The other week I wrote in about my mini (remote change) not finding gears, crunches ,etc. I was advised about a worn clutch arm ball, plus some other good things to check . Anyway I finally changed the clutch arm and adjusted the clutch.
My mini is back changing gears no crunching or grinding. As this post was lost I forgot who gave me the free advice but am thanking you as you will know who you are. Was terrified it was my gearbox - ching ching The slave cylinder did need a bleed as someone else advised. Thanks again Your welcome, glad it worked out. Cheers |
