It is currently Sat Jul 26, 2025 11:00 am
PostPosted: Mon Apr 05, 2010 5:01 pm
My cooper s engine has a damper marked "metal lastik damper" part no 51-139. Can anyone please tell me if this is the correct damper for a cooper s, and also should the damper and pulley assembly be balanced prior to installation.
Should the correct pulley have a part number stamped on it?
thanks.
PostPosted: Mon Apr 05, 2010 5:06 pm
is it 2-pieces??? bolted together by 4x bolts
PostPosted: Mon Apr 05, 2010 5:08 pm
1. Yes it's the correct damper for an S.
2. It's probably not a bad idea to check the balance on a crank before fitting. However, the replacement MED ones available now do not need rebalancing, according to Graham Russell. These look like this one- http://home.exetel.com.au/zoomini/zoomi ... GP2061.JPG
3. The crank pulley (inside damper) on my S motor looks original, but has no numbers.
PostPosted: Tue Apr 06, 2010 8:14 pm
thanks for that info
Users browsing this forum: Bing [Bot] and 85 guests
