cooper s harmonic balancer https://www.ausmini.com/forums/viewtopic.php?f=2&t=62241 |
Author: | oldtimer [ Mon Apr 05, 2010 5:01 pm ] |
Post subject: | cooper s harmonic balancer |
My cooper s engine has a damper marked "metal lastik damper" part no 51-139. Can anyone please tell me if this is the correct damper for a cooper s, and also should the damper and pulley assembly be balanced prior to installation. Should the correct pulley have a part number stamped on it? thanks. |
Author: | TheMiniMan [ Mon Apr 05, 2010 5:06 pm ] |
is it 2-pieces??? bolted together by 4x bolts |
Author: | drmini in aust [ Mon Apr 05, 2010 5:08 pm ] |
1. Yes it's the correct damper for an S. 2. It's probably not a bad idea to check the balance on a crank before fitting. However, the replacement MED ones available now do not need rebalancing, according to Graham Russell. These look like this one- http://home.exetel.com.au/zoomini/zoomi ... GP2061.JPG 3. The crank pulley (inside damper) on my S motor looks original, but has no numbers. |
Author: | oldtimer [ Tue Apr 06, 2010 8:14 pm ] |
thanks for that info |
