It is currently Fri Aug 01, 2025 2:25 am
PostPosted: Thu Apr 08, 2010 9:12 am
hey all i have a van shell at home and was thinking of turning it into a mini-sprint type car.
either that or chopping the whole 3" off the roof instead.
just wondering about the cut lines around the front of the car/bulkhead that are required to do this and if it would look any good or would the length of the van make it look strange.
would really appreciate it if someone could come up with some pics of chopped vans or a photo-shop of a mini-sprint van?
i've done quite a lot of research on this but found nothing on vans so any help is appreciated
1962 850,Frog
PostPosted: Thu Apr 08, 2010 10:29 am
There was at least one Traveller/Countryman cut down by Neville Trickett (The Man) in the sixties.
This photo doesn't really do it justice, but they look quite good.
Cut lines around the front are the same as for a normal Sprint. You will find a few details in some of the threads on the (old) Mk1 Conversions forum. Mark Forster who runs the forum recently had Neville Trickett cut down a sedan for him and he gave some hints (although its Neville's trade secret) about how its done. Just cutting the shell isn't enough, there are a million other small parts that need doing too.
1955 BSA C11G
1961 Morris Mini Traveller
1969 Triumph TR6R
1977 Leyland Moke Californian
PostPosted: Thu Apr 08, 2010 10:54 am
steward and ardern did two vans for Steve Mqueen.
If you just chop the roof then you have to add a section into it.
www.minisprintgt.com
PostPosted: Thu Apr 08, 2010 11:33 am
Mien
I wonder if you could make some kind of elongated tribute to the broadspeed?
PostPosted: Thu Apr 08, 2010 12:18 pm
cadilac fins! :shock:
1962 850,Frog
