Hi all,
Just decided to replace my 78 clubman's tandem master cylinder for a new gmc227 master cylinder, since the old one had rust inside. I knew that the connections were different, so I bought a BAU5654 adaptor kit for it.
After putting the MC in I realised that this wouldn't fit - the pipes are too short and don't reach the valve.
Initially, I thought I'd just bought the wrong kit, because I looked at the minisport site and found that they sold a little brass adapter with their MCs to attach to the lower pipe, since the thread is bigger:
http://www.minisport.com.au/prod604.htm
BUT on another site, it says that the pipes need to be swapped,since the pipes attach to the opposite sides of the valves that the original - this is what I was lead to believe in the first place:
http://www.minis.com.au/minis/catalog/p ... cts_id=850
So, which is it? And where can I get one of these adaptor nuts?
Thanks.
