It is currently Thu Aug 07, 2025 12:45 am
 Post subject: Wanted Weber box plans
PostPosted: Tue Apr 13, 2010 8:25 pm
Hi
I am wanting to put in a weber box in my mini to tidy up the damaged bulk head after the fire.
I plan to run a weber one day and need to make a repair so the time is right.
I would like a template with the numbers etc so i can get one made up
There must be one on the net some where
I have looked and found every thing but
Kiwiinwgtn
PostPosted: Tue Apr 13, 2010 8:30 pm
Don't make it too small or a decent size filter won't fit.. will it, Lillee.. :P
PostPosted: Tue Apr 13, 2010 8:34 pm
High heel ninja
A battery box fits like a glove.
Doogie
PostPosted: Tue Apr 13, 2010 8:39 pm
Dimensions please..
PostPosted: Tue Apr 13, 2010 9:20 pm
no dementions but Dr gave me this thread for inspiration
I purchased a custom made box some time back
Untested not in a Mini but for a Mini
250mm wide 165 high. Depth I know this one has to be cut down to fit as its way past the top an bottom rail on the dash so it just a matter of measuring these rails and adding what you want to over hang inside the engine bay
