It is currently Sun Aug 24, 2025 5:07 pm
 Post subject: Removal of Inner Guards
PostPosted: Sat Apr 17, 2010 3:49 pm
Hey guys, just looking at a local mini for sale, on behalf of the Father in Law, and Old m8 has said his cut the inner guards out to have easier access to the engine bay, I havn't looked in the engine bay yet, but I was wondering if that would have effects when it came around to rego time?
Cheers guys.
Nathan
PostPosted: Sat Apr 17, 2010 4:25 pm
It should make a difference as the inner guards are part of the front of the mini's structural integrity (not like a HQ or similar where there is a full chassis to hold everything together , the inner and outer guards on a mini are structural) . Some pink slip guy's might pass it but most will fail it as being non standard and needing an engineers report .
PostPosted: Sat Apr 17, 2010 5:08 pm
Thats what I thought.
Hopefully when I get to have a look, it will either be a small section cut out, or an easy fix.
Thanks heaps sports850
PostPosted: Sat Apr 17, 2010 6:15 pm
Fancy removing the inner guards to get easy access to the motor, I usually just open the bonnet. :mrgreen:
PostPosted: Sun Apr 18, 2010 7:50 pm
Inner guards are needed on a mini for better cooling.
Under bonnet pressure is required so as to push more air through the radiator. Think about it. :)
