sorry dave68mini i didnt mean to come across as rude. i spent much time trying to get around doing a whole shebang, and after consulting with many people and taking the fantastic advice from the ausmini forum, i came to the decision that i had to accept reality and do it properly.
cutting corners when it comes to mini engines and gearboxes is at high risk of a failure in a short period of time.
i sent my gearbox to lincon at parts and panels in islington NSW. he has been great to deal with and is doing his best to keep costs as low as he can. sending him my gearbox meant that he could use as much as he could from it, and replace only what was needed to bring it back to a good opertaing unit that would last.
i have heard from a few people parts and panels have lots of used gearboxes and a lot of new parts stock, so they are in a good position to be able to source good used parts, mixed with new parts where needed, and assemble one good box at a cost effective price.
lincon is hoping to finish my box this week and is at this point stating that the price will be around $1000. plus or minus a little.
give him a call and discuss some options.
there are lots of mini specialists around though aswell, try someone close to you and get some quotes.
you will more than likley need to take your engine or box to the person quoting on it, so they can have a real look at whats required to do the job.
im in brisbane, and after shopping around a little i decided to send the box to parts and panels. i prefer usually to use local companies as i am a big supporter of keeping your local guys in business, but i origonally had the mindset that i could do this on the cheap.
as i said already, you cant cut corners with these really.
its possible you may be very lucky, remove the box, find no metal filings and everything is sweet as. clean it out and put it back in, but there is no garuntee that it will last, or that you may end up having to remove the whole engine and gearbox again within a short time.
i ended up deciding that if i had it all apart, i might as well do it properly, and do it once! that way when i put my pride and joy back on the road, it will go for many years, and wont stop for something small or silly that i didnt do when i had it apart.
just remember that this is all just advice to. do some ringing around, do some research, read up heaps and take as much feedback from ausmini as you can and make a decision from there.
it comes down to how much money you have well dave68mini.
im just trying to help with advice, speaking as someone who just tried to keep the costs down and got caught out!
hope this helps. good luck man
