fuel injected vs carb/webber https://www.ausmini.com/forums/viewtopic.php?f=2&t=62593 |
Author: | i got a mini [ Tue Apr 20, 2010 10:12 pm ] |
Post subject: | fuel injected vs carb/webber |
Ok straight to the point what is better to get more horsepower injection or carb/webber on a mini motor. |
Author: | Harley [ Tue Apr 20, 2010 10:14 pm ] |
Depends. Generally speaking the siamese head is the bottleneck for injection, so carby on a 5 port head. If you have an 8 port head things can look the other way though. |
Author: | Fat Boy Dave [ Tue Apr 20, 2010 11:03 pm ] |
Most stuff I've seen you can get the same peak horsepower with the carb but the fuel injection makes for a nicer way to get there. |
Author: | blue_deluxe [ Tue Apr 20, 2010 11:10 pm ] |
Like what Harley says. If its 5 port then a carb is what you want. For an 8 port/7 port or bimmer twinky then injection is the go. Siamese port injection is a box you really dont want to open. |
Author: | GT mowog [ Wed Apr 21, 2010 5:57 am ] |
A mate has an Escort. He had a Weber on it and had it dynoed. A few weeks later he put Injection on it and went back to the same dyno to have it set up. The Weber did make more HP, but not by a lot, however the Injection was found to be easier starting (not the the Weber was a problem), smoother all round and better MPG. |
