It is currently Fri Jul 18, 2025 11:51 pm
 Post subject: Morris Rad
PostPosted: Sat Apr 09, 2005 9:37 am
Well I pulled it out this morning and I think it need some work.. :cry:
But guess what else I found..14ml socket..I wounderd where that got to.
but also dam Alternator bracket Broken. Click on the Pic for a better size
..Looks like Marcia will be giving her 17acr again :roll:
Any one interested in a how to pull a Rad info sheet
Edited to add pic's :wink:
PostPosted: Sat Apr 09, 2005 10:01 am
I AM.. last time I did it to replace the engine mount it took me ages.
Do you have an info sheet on the order of putting the damn thing back in..??
 Post subject: radiator
PostPosted: Sat Apr 09, 2005 10:11 am
Hi gafmo,
can i have your instruction sheet as well.
I'm going to put a new 3 core radiator in shortly
Thanks felix
1966 mustang coupe 289 auto
1970 mgb roadster auto
1970 cooper S mk2
1976 mini S
1964 wolseley 24/80
http://s160.photobucket.com/albums/t173/1966mini/
 Post subject: Re: Morris Rad
PostPosted: Sat Apr 09, 2005 12:08 pm
told ya, told ya :D
Good time to do it before it gets too hot again (ambient I mean).
Anton, myself and chong have been round at the Doc's doing various bits and pieces - wondered where you'd got to 8)
KB
PostPosted: Sat Apr 09, 2005 12:37 pm
Well its sort of finished..as per normal I had a fight with those bolts that lock in the suround and the Rad :twisted: but at least the bottom rad pipe went around the suround with ez both times :D
You know those little bolts on the front and rear :twisted: as per normal
Water pump spun easly :wink:
Marcia has donatted here Alternator (lost count now) 17acr and of course the brackets are differnt and the bottom bolt size is differnt :roll:
Can some one remind me with the wireing do the two big terminals of the 17acr go to the same spot on the solinoid
No troubles I'll do up a shet for you's
PostPosted: Sat Apr 09, 2005 2:12 pm
The day I bought my Lancer, I had some ass bandit run into me....
When the panel beaters cut the front rad support panel off, they found a large socket INSIDE the chassis rail.....which means someone had put it there, then welded the rad support in place, trapping the socket in the chassis rail..... :lol:
The bastard kept it...... :evil: My car + socket in chassis rail = my socket! (even though I didn't put it there)
PostPosted: Sat Apr 09, 2005 2:50 pm
I still don't think it fixed..Warmed it up and pumped the Top radiator hose and it wanted to sit on half again...Plus the Ign light is on :roll:
I did get this Alternator fixed after it died last time!
I have also another spare Alternator which is D.E.D so i thought Excellent just change the Covers Over :twisted: that nut on the end does not want to come off :twisted:. I'll let it soak in WD40 for a while before I throught something :lol: :?
PostPosted: Sat Apr 09, 2005 6:49 pm
Wife took it for a spin up to local servo..H straight away and IGn light on..now I'm pissed and will have another look at it tomorrow...
All pipes are clear and thermo only resently new. I can only think thier is a blockage in the head or block :twisted:
If this head come off some thing else will go on :shock:
PostPosted: Sat Apr 09, 2005 7:31 pm
check your temp sensor
PostPosted: Sat Apr 09, 2005 8:00 pm
Yer I'll pull that out tomorrow morning :wink:
I also have one of Wombats regulators inside Binical to change but I can't find the paper that came with it..I'll change that also tomorrow moring also
PostPosted: Sat Apr 09, 2005 11:00 pm
I have the bit of paper from mine but I'm out tomorrow. If you need it post tonight or in the morning, and I'll check the forum before I leave. I think it is black for common, red for 12 volt supply and the other colour (white?) the regulated 10/10.5V or whatever. You can check by following the trace on the backing sheet (PCB) and working out which one goes to earth, which one comes from the plug (+12v), and which one goes to the instruments(+10.5v).
KB
PostPosted: Sat Apr 09, 2005 11:07 pm
Yes that code is correct. I just fitted 2 of 'em.. :wink:
PostPosted: Sun Apr 10, 2005 6:31 am
if you could just let me know what red and White connect to...Black Earth :wink: Cheers
PostPosted: Sun Apr 10, 2005 6:47 am
Red goes to the live green wire,
black goes to the earth lug on speedo,
white one- fit a double spade connector and it then goes to the 2 light green/brown wires- fuel and temp gauges. :wink:
PostPosted: Sun Apr 10, 2005 6:51 am
:wink: Cheers Keven...Wifey still asleep so i'll start banging when see wakes up...I also reliase I have a temp gauge on my altermeter so I'll give that a go also...
But i'm going to lunch and the inlaws are over at 10:30 this morning so not a lot I can do today :cry:
