It is currently Sun Jul 27, 2025 11:44 pm
PostPosted: Fri Apr 23, 2010 11:40 am
Hi,
I've had a search and can't find anything, but I need to make a bracket for a VH44 brake booster for a clubman. I can probably wing it, but a reference photo of an OE one would be a good starting point.
TIA,
Simon.
PostPosted: Fri Apr 23, 2010 2:29 pm
very simple for a VH44, just a wide piece of flat, bent at right angles to pick up the two front bolts and one at the rear. There are 2 captive bolts that go through the plate and into the inner guard
PostPosted: Fri Apr 23, 2010 3:25 pm
Or buy one from Hydroboost
http://www.hydroboost.com.au/index.htm
PostPosted: Fri Apr 23, 2010 5:36 pm
Perfect - thanks Simon.
