Brake booster mounting bracket - photos? https://www.ausmini.com/forums/viewtopic.php?f=2&t=62632 |
Author: | Angusdog [ Fri Apr 23, 2010 11:40 am ] |
Post subject: | Brake booster mounting bracket - photos? |
Hi, I've had a search and can't find anything, but I need to make a bracket for a VH44 brake booster for a clubman. I can probably wing it, but a reference photo of an OE one would be a good starting point. TIA, Simon. |
Author: | simon k [ Fri Apr 23, 2010 2:29 pm ] |
very simple for a VH44, just a wide piece of flat, bent at right angles to pick up the two front bolts and one at the rear. There are 2 captive bolts that go through the plate and into the inner guard |
Author: | winabbey [ Fri Apr 23, 2010 3:25 pm ] |
Or buy one from Hydroboost http://www.hydroboost.com.au/index.htm |
Author: | Angusdog [ Fri Apr 23, 2010 5:36 pm ] |
simon k wrote: very simple for a VH44, just a wide piece of flat, bent at right angles to pick up the two front bolts and one at the rear. There are 2 captive bolts that go through the plate and into the inner guard
Perfect - thanks Simon. |
