Ignition Light on While Driving
https://www.ausmini.com/forums/viewtopic.php?f=2&t=6266
Author:  sg [ Mon Apr 11, 2005 7:47 pm ]
Post subject:  Ignition Light on While Driving
Guys, as title says the ignition light is staying on whilst driving...... is it a wiring problem, or something more sinister (Alternator :shock: )
Author:  drmini in aust [ Mon Apr 11, 2005 7:51 pm ]
My money is on the alternator, (or the V regulator if it's the early 15AC with separate reg so beloved by S owners...)
Could just be slip ring brushes- if so it's a cheap easy fix on `most' Lucas alternators. :wink:
Author:  sg [ Mon Apr 11, 2005 8:06 pm ]
Doc.... whereabouts is the V Regulator in the engine :oops:
Author:  gafmo [ Mon Apr 11, 2005 8:32 pm ]
O dear it's Spreading
Author:  TheMiniMan [ Mon Apr 11, 2005 8:52 pm ]
I`d just check that the fan belt is actually still on there first,,,
If it is,,,then look at the wiring or altinator for faults
Author:  drmini in aust [ Mon Apr 11, 2005 9:08 pm ]
With a 15AC alternator it's on the RH inner guard, a square box about fag packet size.
On all the ones since (ie Clubbie ones) it's inside the alternator. More reliable.
:idea: Get a spare (good) alternator- it's a handy thing to have if you drive a Mini.. :lol:
Author:  JC [ Mon Apr 11, 2005 9:20 pm ]
Ha haaaaa....take that you hack...
Author:  NAV [ Tue Apr 12, 2005 12:11 am ]
Very good advice. Been stuck on the side of the road with a seized alternator which snapped the belt. all in the middle of nowhere well ok kempsey that added an extra 5hrs to my 12hr trip
Author:  sg [ Tue Apr 12, 2005 4:35 pm ]
Problem when checked this arvo was intermittent..... changed the V Regulator and the problem seems to have disappeared :? ........ hopefully that was the cure :?
