It is currently Sun Jul 20, 2025 8:24 pm
PostPosted: Mon Apr 11, 2005 7:51 pm
You know how they made the limited edition coopers in the nineties. I learnt that these had diffeent gearboxes that apparently make the engine go a little harder. Is this true? iv'e seen pictures and they look different from the outside. Is the engine built differently?
I was thinking of gettin a rebuilt later model engine and gearbox for my clubbie later on, maybe a few years, would it be worth it or should I just get a rebuilt 1275 Gt motor and gearbox.
Mini Clubman, 1.3i, air con, 12" mags, pioneer sound system.
PostPosted: Mon Apr 11, 2005 8:58 pm
Hey? late model? how late? 2000?
I think the SPI (single point injection) and MPI (multi) minis were all still rod change boxes weren't they? :?
PostPosted: Mon Apr 11, 2005 10:03 pm
Im not sure, i think they were late 90's but I can't find any info on them.
PostPosted: Mon Apr 11, 2005 10:06 pm
Don't know about later boxes going harder. The A+ boxes are stronger, but sap a bit more power because they have more of a helical cut on the gears to make them quiet. Me, I like the straight cut variety, especially drop gears!
PostPosted: Mon Apr 11, 2005 10:47 pm
A+ BLOCK may be a little stronger (it has a webbed cast to limit flexing), but then there's always the 1100S block ;)
IMO the A+ motor is highly over-rated...especially in fuel injection guise. Give me a rip-snorting dellorto any day :wink:
A 1275GT motor, which is just an S block will have alot more potential for power than a later fuel injected motor.
There was a 5spd 'box, but these couldn't handle even stock power and had alot of problems..
<edit> The only thing gearbox wise that will make a significant difference is the diff. ratio. Get a 3.647 diff and it will accelerate harder ;)
Users browsing this forum: Dan69s, Scoop and 78 guests
