Later Model Engine and Gearbox, whats the Difference??? https://www.ausmini.com/forums/viewtopic.php?f=2&t=6267 |
Author: | snowie [ Mon Apr 11, 2005 7:51 pm ] |
Post subject: | Later Model Engine and Gearbox, whats the Difference??? |
You know how they made the limited edition coopers in the nineties. I learnt that these had diffeent gearboxes that apparently make the engine go a little harder. Is this true? iv'e seen pictures and they look different from the outside. Is the engine built differently? I was thinking of gettin a rebuilt later model engine and gearbox for my clubbie later on, maybe a few years, would it be worth it or should I just get a rebuilt 1275 Gt motor and gearbox. |
Author: | Lillee [ Mon Apr 11, 2005 8:58 pm ] |
Hey? late model? how late? 2000? I think the SPI (single point injection) and MPI (multi) minis were all still rod change boxes weren't they? ![]() |
Author: | snowie [ Mon Apr 11, 2005 10:03 pm ] |
Im not sure, i think they were late 90's but I can't find any info on them. |
Author: | Anto [ Mon Apr 11, 2005 10:06 pm ] |
Don't know about later boxes going harder. The A+ boxes are stronger, but sap a bit more power because they have more of a helical cut on the gears to make them quiet. Me, I like the straight cut variety, especially drop gears! |
Author: | Mini Mad [ Mon Apr 11, 2005 10:47 pm ] |
Post subject: | Re: Later Model Engine and Gearbox, whats the Difference??? |
snowie wrote: You know how they made the limited edition coopers in the nineties. I learnt that these had diffeent gearboxes that apparently make the engine go a little harder. Is this true? iv'e seen pictures and they look different from the outside. Is the engine built differently?
I was thinking of gettin a rebuilt later model engine and gearbox for my clubbie later on, maybe a few years, would it be worth it or should I just get a rebuilt 1275 Gt motor and gearbox. A+ BLOCK may be a little stronger (it has a webbed cast to limit flexing), but then there's always the 1100S block ![]() IMO the A+ motor is highly over-rated...especially in fuel injection guise. Give me a rip-snorting dellorto any day ![]() A 1275GT motor, which is just an S block will have alot more potential for power than a later fuel injected motor. There was a 5spd 'box, but these couldn't handle even stock power and had alot of problems.. <edit> The only thing gearbox wise that will make a significant difference is the diff. ratio. Get a 3.647 diff and it will accelerate harder ![]() |
