Leyland Mini Air Pump https://www.ausmini.com/forums/viewtopic.php?f=2&t=62753 |
Page 1 of 2 |
Author: | ministar [ Wed Apr 28, 2010 7:41 pm ] |
Post subject: | Leyland Mini Air Pump |
Does the air pump serve any other purpose apart from reducing emissions? Well its supposed to reduce the emissions isn't it? Whats happens if I disconnect it, should I? The car is all original and untouched engine. Maybe its best if I leave it..... Your comments please... ![]() |
Author: | GT mowog [ Wed Apr 28, 2010 7:48 pm ] |
It was only fitted to 'reduce' emissions although all they really did was dilute the exhaust gases with more air. Oh well, they did meet the regulations of the time. Easiest thing to do is remove the belt. Then it's all still there and easily resurected if required, but usually the air pumps sieze up if not used for a while. |
Author: | Harley [ Wed Apr 28, 2010 7:48 pm ] |
I don't think technically it reduces the emissions, merely waters them down so its percentace relative to to the exhaust is lower. ![]() |
Author: | ministar [ Wed Apr 28, 2010 7:51 pm ] |
If I disconnect it will I have an increase in power? Is the engine running any harder with in connected? |
Author: | Morris 1100 [ Wed Apr 28, 2010 7:52 pm ] |
There is no longer a requirement to keep the ADR27A emissions systems working. The petrol it was designed for is no longer available and the systems will not work as designed. If your car is totally stock I would want to leave it intact to keep the stock appearance. So I would block the pipes where they go into the head, leave the belt off the pump and block off any other bits I have forgotten. (a small ball bearing or lead sinker shoved up a rubber hose is otherwise invisible!) |
Author: | GT mowog [ Wed Apr 28, 2010 7:53 pm ] |
It does suck some HP from the engine but not a lot. It will run quieter without the pump ![]() |
Author: | Morris 1100 [ Wed Apr 28, 2010 7:56 pm ] |
The air pump does not water down the exhaust to reduce emissions. It is to add air so that excess unburned fuel can get burned off inside the exhaust system. (and raise the exhaust temp and burn exhaust valves) If you rig them up right you can get a nice flame out the pipe! ![]() |
Author: | Mick [ Wed Apr 28, 2010 7:57 pm ] |
Morris 1100 wrote: If you rig them up right you can get a nice flame out the pipe! ![]() Well thats a plus... |
Author: | ministar [ Wed Apr 28, 2010 7:58 pm ] |
Ok. So there is only one belt that it runs off. Removing that wont effect anything else? sorry, I havnt had a close look at it ![]() |
Author: | GT mowog [ Wed Apr 28, 2010 8:02 pm ] |
No, it'll be fine. If your worried, just try it. You can always put the belt back on! |
Author: | ministar [ Wed Apr 28, 2010 8:07 pm ] |
Yeah true. Thanks for all of your help. I'm just having a read up on it in the Gregory's Manual. |
Author: | Harley [ Wed Apr 28, 2010 8:18 pm ] |
Could you re-route the air into the car for 70s style AC? ![]() |
Author: | GT mowog [ Wed Apr 28, 2010 8:23 pm ] |
Harley wrote: Could you re-route the air into the car for 70s style AC?
![]() Maybe if you rigged the windscreen washers to spray in to it, then you could get evapoative cooling ![]() |
Author: | Bubbacluby [ Wed Apr 28, 2010 8:24 pm ] |
If it were me i would leave it alone while its working. Why fix fix something if its not broke. I would doubt the increase in power would be even noticeable. Just leave all connected till something goes wrong then block it up and take belt off etc thats what i would do |
Author: | Morris 1100 [ Wed Apr 28, 2010 8:30 pm ] |
Bubbacluby wrote: If it were me i would leave it alone while its working. Why fix fix something if its not broke. I would doubt the increase in power would be even noticeable.
Just leave all connected till something goes wrong then block it up and take belt off etc thats what i would do It is not working. It can't work. They do not make the right petrol for it to work. It is just robbing power and doing nothing to help. This is why the Government has removed ADR27A from the books. It is a waste of time and energy to leave it in place. It costs power to turn the pump. If you wanted to create less pollution you would disconnect it. |
