It is currently Fri Jul 18, 2025 9:18 am
PostPosted: Mon May 17, 2010 12:35 pm
Resident Haemorrhoid
as stated the sump plug came undone about a third and just spins :evil: :evil: :evil: and wont come out any further :evil: :evil:
any ideas hints etc
i guess i am up for a new sump plug so how do i get the bloody thing out without having to remove the motor
mtsmini wrote:
Tombo wrote:
PostPosted: Mon May 17, 2010 12:40 pm
that's wierd....
put a flat screwdriver behind the head and lever it against the gearbox casing as you undo it - basically to put outward pressure on the bolt while it's undoing
PostPosted: Mon May 17, 2010 12:42 pm
You need a fork like device to lever a little outward force for under the bolt bolt head while you turn it. Hopefully it will re engage a thread and keep coming.
A grinder disc tightening tool would be along the lines of something I might try first up before I got serious.
PostPosted: Mon May 17, 2010 1:00 pm
Gadgets,
You have stripped the thread in the gearboxl.
You will need a helicoil in the gearbox.
The sump plug will be the least of your worries!!!!
To get the plug out lever behind the hex of the plug as you turn it as the others have said..
Steve
1964 998cc Cooper
1971 Mini K x 2
1972 Clubman GT
PostPosted: Mon May 17, 2010 1:08 pm
thanks Guys,
I will give that a try
I was worried by prying that the bolt would come apart and end up in the gear box
mtsmini wrote:
Tombo wrote:
PostPosted: Mon May 17, 2010 1:13 pm
You would crack the ally gearbox case before you snapped the bolt in two.
PostPosted: Mon May 17, 2010 3:43 pm
are Helicoils a DIY or best done in a workshop??
mtsmini wrote:
Tombo wrote:
PostPosted: Mon May 17, 2010 4:00 pm
You can do it yourself but you have to ensure you're tapping the hole staight and square to the sealing face for the washer otherwise it'll leak.
PostPosted: Mon May 17, 2010 4:06 pm
one that big is a workshop job - the kit to do it would cost a fortune. Any of the mini shops would be very experienced with doing them
PostPosted: Mon May 17, 2010 4:12 pm
cheers.
Off to Melba motors i go :wink:
mtsmini wrote:
Tombo wrote:
PostPosted: Mon May 17, 2010 4:58 pm
If your going to do it yourself, see if wurth does a timecert the for the size you need their stronger than helicoils and i have'nt seen on stuff up yet.
LUCAS ENGLAND
"Ride hard or die trying"
PostPosted: Mon May 17, 2010 5:06 pm
1964 998cc Cooper
1971 Mini K x 2
1972 Clubman GT
PostPosted: Mon May 17, 2010 5:27 pm
http://www.metalockaustralia.com/thread_repairs.php
PostPosted: Mon May 17, 2010 8:24 pm
8)
ok does anyone know what size thread /depth a sump plug is??
Doc??
mtsmini wrote:
Tombo wrote:
PostPosted: Mon May 17, 2010 8:51 pm
Mods rock!
Off the top of my head (or off my head?) they are 5/8" UNC. One of the mini suppliers had a tapered 'repair' sump plug kit available.
