Another 7 port....
https://www.ausmini.com/forums/viewtopic.php?f=2&t=62765
Page 1 of 2
Author:  Trog [ Thu Apr 29, 2010 8:10 am ]
Post subject:  Another 7 port....
Hi folks, just seen this new product from Specialist Components in the UK...
http://www.specialist-components.co.uk/ ... _info-null
My first thoughts are...
Will a billet head have enough coolant flow through it?
The inlet ports are different lengths/shapes... How much would that matter?
With the exchange rates as they are the price is not too bad either!
What are the thoughts from our Guru's?
Author:  Aussie Brian [ Thu Apr 29, 2010 9:46 am ]
looks yummy
Author:  GT mowog [ Thu Apr 29, 2010 10:51 am ]
Really the only way to answer these questions is to get a hold of one and test it. They have been around for nearly a year now, probably not long enough to have any meaningful feed-back from others who have them.
I doubt that cooling would be an issue. Being a billet, they have one advantage over cast - no risk of porosity, but being a billet makes them more expensive than cast.
Author:  Bubbacluby [ Thu Apr 29, 2010 12:59 pm ]
looks very nice. i couldnt find a price though.. how much is it??
Author:  Aussie Brian [ Thu Apr 29, 2010 1:07 pm ]
go to this page for price
http://www.specialist-components.co.uk/ ... gine+Parts
Author:  Mini68 [ Thu Apr 29, 2010 1:15 pm ]
Prices are at the bottom of the page. It certainly looks like great value compared to all the other heads and conversions available. At today's exchange rate it's AUD$4253 (plus shipping, duty and GST etc) for the complete package:
Fully Assembled Cylinder Head with complete Engine Management System
- Billet alloy 7 Port cylinder head as listed above
- 36mm bespoke direct-to-head billet shaftless individual throttle bodies
- SC Typhoon engine management ECU with USB PC interface and software
- Custom throttle linkage and throttle cable
- Complete bespoke high quality wiring loom with all sensors
- SC A-series trigger kit and sensor
- Set of new fuel injectors
- Bespoke stainless steel fuel rail
- Variable length screw on billet ram pipes (Fits round-nose Mini
Author:  73GT [ Thu Apr 29, 2010 1:16 pm ]
Price seems very reasonable compared to a modified 5 port head.
surprised that the power of the 1380 with RE13 cam isnt that much higher than quoted on this forum using a 5 port head
Author:  Trog [ Thu Apr 29, 2010 1:36 pm ]
Quick cost comparrison:
SC head is 1275 pounds, $2095.46
Minisports 7 port is 1519 pounds, $2497.81
Eldar head is about $3250
The SC head, with throttle bodies, injectors, engine management system, etc. is 2552 pounds, $4192.94 which ain't a bad price me thinks.
All these are subject to GST and delivery!
So the billet head is the cheapest!
Author:  david rosenthal [ Thu Apr 29, 2010 8:21 pm ]
there is nothing wrong with a head machined out of a solid lump of alloy as long as the water jacket is opened out enough.
many years ago when mini's were the big thing a bloke here in adelaide,Doug Trengove was building a "clubman " car for rod and track use. Ther early one ran a BMC "A" series out of a morris minor.One of his projects was a 8 port cross flow alloy head, but with a difference. It was 4 individual heads.
Each head was machined out of a block of alloy and ran two water manifolds[1 inlet, 1 outlet] to link them together with 2 bolts to hold them together, with a few more bits and pieces. Simple and effective, many pommy diesels had same set-up.
I know he built some for minis , his son colin ran one on a race car, along came toyota corrolla engines and goodby BMC
this is a cicada clumbman with BMC
Author:  poeee [ Fri Apr 30, 2010 1:54 pm ]
Very impressive for it's price.
Anyone asked for delivery costs to Australia?
Author:  TheMiniMan [ Sat May 01, 2010 12:17 am ]
yeah but,,, i can`t say,,, it`s a secret & if i told you then i`d have to kill you
I would have to say,,, from my own humble, inexperienced, lack of understanding of all things that,,, in my opinion,,, it looks to be Probably the very best 7-port a-series designed & manufactured cyl head available,,,,, to date :-)
Author:  poeee [ Sat May 01, 2010 12:22 pm ]
Looks at credit card...
Then need a Quaife ATB, not to mention freshening up the rest of the engine. Gearbox should be good enough.
Author:  TheMiniMan [ Sat May 01, 2010 12:32 pm ]
ahaaa,,, famous last words :-)
Author:  Mick [ Sat May 01, 2010 12:50 pm ]
Hmmmm....
Author:  Davo111 [ Sat May 01, 2010 12:53 pm ]
get bact to studdying and stop drooling all over the keyboard :wink: :wink:
