It is currently Fri Aug 22, 2025 6:21 pm
 Post subject: Engine oil choice
PostPosted: Sun May 02, 2010 8:35 pm
hi everyone,
i know this is a can of worms, but i am about to run a new engine in and wanted to get everyones feedback. i will be running the runin oil for about 500-800kms.
what are your suggestions for running in oil? Brand and visocity?
what do you suggest for standard use oil after running in? Brand and viscosity?
the engine is a daily driver, freshly built. i will be using a non-friction modified oil in mineral form. no synthetics.
Thanks
jason 8)
PostPosted: Sun May 02, 2010 8:39 pm
just use what your engine builder sugested to you
and once she is run in run whatever is cheapest or has the pakaging that apeals to you as long as you change it when your meant to you will be right it :?
PostPosted: Sun May 02, 2010 8:44 pm
:lol: yeh. well i am the engine builder so its up to me! :lol:
I am probably going to use something like 15w40 to run in and 20w50 for normal use once its run in.
just wanted to get peoples feedback on brands etc.
does anyone use castrol edge sport or penzoil oils? i have used these in the past and found them very good with other engines.
KMX from Kmart..Its perfect all round which every way you look at it
PostPosted: Sun May 02, 2010 8:49 pm
i like castrol oils and always have used them on all my cars :D
PostPosted: Sun May 02, 2010 8:50 pm
Just to put my two bob in when I did my engine in my delux
I had a valvoline running in oil in it for 1000Kms then I changed the oil and filter and I am using penrite HPR15 which is a 15w 60 and I have been changing both every 5000Kms
Don't under estimate the power of a Mini
1975 Supercharged Blue Mokezilla ;)
1976 Fudge Moke
1967 BRG & White 67 Morris Deluxe
1974 Clubman Mini S
2005 Red Mini Cooper S
2009 Mitsubishi Outlander VRX
PostPosted: Sun May 02, 2010 9:08 pm
I asked the same question once.
This thread may be of some help:
http://www.ausmini.com/forums/viewtopic.php?t=56922&highlight=oils+aint+oils
Justin
PostPosted: Sun May 02, 2010 9:58 pm
KMX, Doesnt taste all that bad either if your unfortunate enough to happen to drink it
Simplify and add lightness
PostPosted: Sun May 02, 2010 10:32 pm
This space for rent
I used to swear by Penrite HPR30 back in the late '90s, before they changed it to an API-SM formula.
Then I switched to what became Castrol Edge Sport, which is (still) a good oil but pricey.
Now I won't use anything but Motorpro KMX from K-mart. I tried it based on the advice given here by the Doc and GR, and my experience since has been that it's as good or better than the Castrol -- higher and more consistent oil pressure, less burnt over time and retains its "purity" for longer between changes.
At the full price of $20 per 6L it's about half the price of the Castrol, to boot.
PostPosted: Sun May 02, 2010 11:09 pm
can this be mixed wiyh cola in substitution of bourbon :lol:
PostPosted: Sun May 02, 2010 11:13 pm
This space for rent
I was wondering what circumstances would arise which would lead to a slug of KMX in the mouth... but I thought better of it :lol:
PostPosted: Sun May 02, 2010 11:14 pm
I thought it was a water leak, and the best idea at the time seemed to be taste. In hindsight there are definitely better methods.
PostPosted: Sun May 02, 2010 11:16 pm
This space for rent
:shock:
Not many ideas floating around at the time then, it seems :lol: :lol:
See if that was Castrol Edge you would have thought twice before spitting it out. I'm sure they put some vanilla essence in that stuff to make it smell sweet...or its the simply the smell of olfactory cells mutating into cancerous growths.....
PostPosted: Sun May 02, 2010 11:18 pm
This space for rent
For the price you'd think twice about spitting, I'm sure :shock:
Users browsing this forum: No registered users and 271 guests
