It is currently Wed Aug 06, 2025 8:44 pm
PostPosted: Fri May 07, 2010 10:45 pm
I was doing a delivery to a mattress company the other day and while driving my truck through their yard I noticed a couple of rolls of padding. Same consistancy as a Furniture blanket but about three times thicker. I'm replacing the roofliner in Hetty and needed something to stop the drum noise when the roof is thumped from above.
Went to the Domain offsite warehouse and cut open an old Queen size mat I then proceeded to pull out the padding. It was the same stuff. After cutting out the pattern to fit to the roof I applied some spray adhesive and stuck it up.. The difference is phenominal and completely free. It's also recycling something that would normally be reserved for landfill. I will be using it for other areas of the car...
*WARNING* This padding is NOT. I reapeat NOT in anyway flame retardant. I tested it and it did start to burn. I wouldn't use it in the engine bay.
PostPosted: Sat May 08, 2010 10:22 am
Image :wink: :P
-James.
Toyota 4EFTE Powered Minivan.
PostPosted: Sat May 08, 2010 11:32 am
a delivery driver at work said its great stuff. He is in a band and uses it as sound proofing in his shed.
blokeinamoke wrote:
PostPosted: Sat May 08, 2010 6:45 pm
Is that the thick grey material with multicoloured specks in it?
Thick woolen type stuff, easy to pull apart with your hands? I cut up a queen size ensemble and it had that under where the mattress sits, might salvage it if it's what you're talking about..
You're so square
Baby I don't care
PostPosted: Sat May 08, 2010 8:35 pm
Yes basically a mattress is made up of a few different layers. First is the outer fabric (ticking) then a layer of foam and then the grey wadding type material, all this covers the springs. So in essense a Queen size mat gives you almost three square metres..
It's been up for a couple of days and so far it's not fallen off.
PostPosted: Sun May 09, 2010 11:21 pm
Got a pic to confirm what it looks like?
-Alan
PostPosted: Mon May 10, 2010 12:26 am
I'll get you one in the morning mate.
PostPosted: Mon May 10, 2010 10:54 am
I found another good sound deadener.... its called a mouth zip
I have tried it and it really works. No more painful noise.
PostPosted: Mon May 10, 2010 11:08 am
The only problem is getting her through the sewing machine! :wink:
-James.
PostPosted: Mon May 10, 2010 1:05 pm
Best picture I could muster up. I'm thinking maybe only half of it would be needed because it's just to get the resonance out of the roof. I'll pull half of it out and use it elsewhere..
PostPosted: Mon May 10, 2010 1:20 pm
From the factory, they only used a piece of hession about 900mm x 750mm for the roof (that's what I measured on mine when I removed the hoodlining)
-Alan
PostPosted: Mon May 10, 2010 1:23 pm
You probably need to stop people banging on your roof. Unless it's an early body (with thicker metal) it will dent. How do I know............
PostPosted: Mon May 10, 2010 8:14 pm
I know all about it. When I first bought the car I look about 5kg of bog out of the roof :shock:
Users browsing this forum: drmini in aust, phillb and 84 guests
