Really boring questions https://www.ausmini.com/forums/viewtopic.php?f=2&t=62969 |
Author: | adamstuart [ Sat May 08, 2010 8:19 pm ] |
Post subject: | Really boring questions |
A few questions on bores, their output and stability. 998: How big a bore can you go? How stable is this bore? What is needed to go to this bore? 1275: How long is 1380 likely to last, under what conditions? |
Author: | drmini in aust [ Sat May 08, 2010 8:30 pm ] |
Post subject: | Re: Really boring questions |
adamstuart wrote: A few questions on bores, their output and stability.
998: How big a bore can you go? +.120" is easiest max, but you can get to 68.0mm. How stable is this bore? No problem, these blocks are pretty thick. What is needed to go to this bore? For +.100" or +.120", a set of pistons and a bore+hone job. For 68mm you need Imp pistons + 1100 crank, or bike pistons (more $$$) 1275: How long is 1380 likely to last, under what conditions? As long as a 1275 rebore would. ie same as original. But I like to go with 1360, it leaves another bore job for later. No power difference. |
Author: | adamstuart [ Sat May 08, 2010 8:45 pm ] |
Thanks dr mini, if something was to go wrong with a 1380 bore could it be sleeved and the engine still be good? Or if a 1380 dies then it's dead. Also, what kind of output would the 990 +.120 give? 998+120=1118? |
Author: | drmini in aust [ Sat May 08, 2010 9:30 pm ] |
You can bore a 1380 to 1400 (if it was offset bored to 1380 or sooner). Graham Russell can sleeve either a 1380 or a 1400 back to whatever size you need, from 1275-1380. |
Author: | Kennomini [ Sun May 09, 2010 10:22 am ] |
So their is no hp or torque difference between the 1360 and 80? or just not enough to notice in a fast daily driver? |
Author: | drmini in aust [ Sun May 09, 2010 10:40 am ] |
True. And once you bore further to 1400 or more, the cylinder walls get thinner and ring sealing gets worse. This is why turbo 1275 motors are usually kept to +.060" or less. Want more cubes, stroke it. ![]() |
Author: | micowen [ Sun May 09, 2010 11:26 am ] |
Sorry to jump in with a question, but do you guys reckon that it would be a bit stupid to take a mild stroker 998 and bore it to 100 thou? This is for a daily driver mind you, not for the track. Would you if you could or is this in the overkill basket? |
Author: | poeee [ Sun May 09, 2010 11:37 am ] |
If you want more CC's out of your 998, just simply go to the next usable bore size and put a 1098 crank in it. |
Author: | drmini in aust [ Sun May 09, 2010 1:19 pm ] |
poeee wrote: If you want more CC's out of your 998, just simply go to the next usable bore size and put a 1098 crank in it.
No problem boring a 998 or 1098 block to +.100", block is thick & pistons are cheap. A 1098 crank and +.100" pistons will give you 1188cc. No substitute for cubes, if you want good torque for a roady. ![]() |
Author: | adamstuart [ Sun May 09, 2010 2:30 pm ] |
drmini in aust wrote: Want more cubes, stroke it.
![]() What is involved in "stroking it" inbeforelamejokes. |
Author: | drmini in aust [ Sun May 09, 2010 2:37 pm ] |
adamstuart wrote: drmini in aust wrote: Want more cubes, stroke it. ![]() What is involved in "stroking it" inbeforelamejokes. Stroking an engine means increasing the stroke of the crank. A few ways- 998 motor- fit a 1098 crank & pistons, stroke is 7.5mm longer, it adds 100cc. 1275 motor- 1. get a big journal (1.750") 1275 crank, have the big ends offset ground down to 1.625", use Cooper S rods, deck the pistons 1.5mm. This gives about a 3mm stroke increase (more possible if you go undersize on the big ends). Cost: around $240 for crank grinding. OR 2. Get a longer stroke crank made, say 86mm stroke. Cost $,$$$. |
