alternator problems https://www.ausmini.com/forums/viewtopic.php?f=2&t=6297 |
Author: | djstib [ Tue Apr 12, 2005 11:27 am ] |
Post subject: | alternator problems |
On the back of the alternator there is 3 male pins.. Ones large so i know which wire goes there... but the other 2 are small ones.... now which wire goes to which? one of the small wires has 12v's going through it the other has none... all this is because my battery is not charging... |
Author: | MrBob [ Tue Apr 12, 2005 11:55 am ] |
Just put a commodore alternator in like i did!! I think even when I get my 4-spot nudge bar and a decent stereo I'll be fine with 85 amps or whatever it is!!! |
Author: | bigel nigel [ Tue Apr 12, 2005 12:35 pm ] |
just put ur battery terminals on backwards like litle green mini did that will fry all ur alternater wires take it to an auto electrition and they will give u all new wires and they will connect it for u ![]() actually don't do that, thats a bit of a dumb idea isn't it John aka little green mini ![]() ![]() |
Author: | djstib [ Tue Apr 12, 2005 12:42 pm ] |
common guys i need help... not jokes |
Author: | bigel nigel [ Tue Apr 12, 2005 12:54 pm ] |
yeah sorry bout that couldn't help my self bad bigel bad boy but yeah some one help him i can't help but i can give some advise when i took my alternator off i drew a picture of where the wires went and put tape around them to lable them ![]() it worked for me |
Author: | drmini in aust [ Tue Apr 12, 2005 5:59 pm ] |
If it has 2 small ones next to each other, it's probably a 15AC alternator that uses a separate V regulator on the RH inner guard. These 2 wires both go to the regulator- the yellow/black one is the indicator lamp circuit. If the alternator quits I suggest you go find a later Clubbie one which has the reg built in and is more reliable. Then, you just connect the yellow/black wire to the Ind terminal, and the big brown wire to +, and it will work. ![]() |
