KAD shifter - never mind Viagra, look at this!!
https://www.ausmini.com/forums/viewtopic.php?f=2&t=62978
Author:  mtsmini [ Sun May 09, 2010 2:54 pm ]
Post subject:  KAD shifter - never mind Viagra, look at this!!
Spent 3 hours at the weekend cleaning the rod shifter box and fitting a KAD shifter. Oh yeah baby...
I've also come to the conclusion that, like all British vehicles, most of the grease and oil appears to be on the outside of items rather than sealed inside! :?
The shifter box only has a metal to metal slider sealing the front and the steel plate in the base has an open drain hole. :shock:
Author:  Super-mini [ Sun May 09, 2010 2:57 pm ]
so you like fishing then...
Author:  drmini in aust [ Sun May 09, 2010 2:59 pm ]
It's called `agricultural engineering'.
The factory paid scant attention to the need for lubrication.
Author:  1310/71 [ Sun May 09, 2010 3:45 pm ]
That's why he went for a rod change! :D
Author:  Tombo [ Sun May 09, 2010 10:37 pm ]
Hehe, at least you know if it's going to be an odd or an even gear :roll: :lol: :lol:
Author:  mtsmini [ Mon May 10, 2010 9:17 am ]
Post subject:  kad
Weight saving :)
Author:  Maxi23 [ Mon May 10, 2010 9:21 am ]
Very nice.
Is this car a track car ? The amount of KAD goodies is insane.
Author:  kiwiinwgtn [ Mon May 10, 2010 9:49 pm ]
looks good, what did you use to clean up the aluimium
Author:  TheBlackMini [ Mon May 10, 2010 10:18 pm ]
Noice!
Author:  Gareth_1330 [ Fri May 14, 2010 9:42 am ]
out of interest, did you re bush it?. When i did mine i turned the rod around, so the warn end was at the front, and rebushed the housing. Made the whole arrangement feel infinitely tighter 8)
Author:  blue_deluxe [ Fri May 14, 2010 1:30 pm ]
Are you going to move the whole assembly inside the car? It always looks good and you can see the shiny bits.
Author:  TheMiniMan [ Sat May 15, 2010 5:24 pm ]
send me the KAD rear trailing arms & disc assys ok? i`ll look after them for you while you fit the shifter :-)
