New CV joints
https://www.ausmini.com/forums/viewtopic.php?f=2&t=62979
Author:  harry33 [ Sun May 09, 2010 4:05 pm ]
Post subject:  New CV joints
Hi all,
How tight should new disc brake CV joints be?
I couldn't move the inner cage by hand, so I took them apart, greased everything, and put it back together, but that doesn't seem to have made much of a difference. I can move them by putting the driveshaft in and levering it around, but it's still pretty stiff.. Is this normal, or should they be easier to move than that (I can move the cage in the old drum brake CVs very easily)?
Harry
Author:  CPOCSM [ Sun May 09, 2010 4:56 pm ]
They should be like that out of the box. When you get them installed and in the road, they will loosen up when the high peaks wear down. Just grease them as normal and go gently for the first fang out. They will loosen up once everything is buttoned in.
I must get my butt into gear and get myself motivated to finishing off my little mini - been nearly 3 years now since I took him off the road. At this rate the engine I put together 2 years ago will be buggered before I even turn it over!!
Hooroo
Author:  Dave68Mini [ Mon May 10, 2010 12:28 pm ]
I cant even get my joints apart :shock:
I've followed the instructions in the manual (hold vertical and smack with a copper hammer) but nothing is moving.
Maybe Im not smacking hard enough.
Dave
Author:  Mick [ Mon May 10, 2010 12:52 pm ]
Watch your feet!
Author:  peterw [ Mon May 10, 2010 1:19 pm ]
You do have to hit them pretty hard. Short sharp bang. There's a circlip inside and the sharp bang makes it retract and the shaft will come out. You need to hang on to the shaft with your other hand or it can hit the ground with a bang.
Pete
Author:  John Smidt [ Mon May 10, 2010 9:19 pm ]
Dave
Are Your Drive Shafts, Cooper S Shafts
