Valve Spring Shims https://www.ausmini.com/forums/viewtopic.php?f=2&t=63019 |
Author: | Rookiepilot [ Tue May 11, 2010 7:42 pm ] |
Post subject: | Valve Spring Shims |
Does anyone is Aus sell these? The only place I have found them is from Minispares in the UK. Heaps of V8 ones available, but too big to modify. Is there anything else I can use? http://www.minispares.com/Product.aspx?ty=pb&pid=41251&title= |
Author: | drmini in aust [ Tue May 11, 2010 7:49 pm ] |
You could maybe use 12mm flat washers and have them surface ground to the thickness you need? |
Author: | GT mowog [ Tue May 11, 2010 7:49 pm ] |
I don't know if any of the local suppliers have them, however have you looked at hardened washers? |
Author: | mini053 [ Wed May 12, 2010 7:44 am ] |
Hi Rookie, Champion parts do a blister pack of 5/8"id x 1" od x 0.028" thick spacing washers which are perfect for setting your installed heights. I reckon I got a pack of 100 from Abbot Supply here in Bendigo. Otherwise you can make your own out of shim stock....you can get different thicknesses from most bearing suppliers. Hope that helps. ![]() Cheers, Greg |
Author: | Rookiepilot [ Wed May 12, 2010 10:10 am ] |
Thanks everyone for your replys. Greg you are a legend. I was only in Abbotts yesterday. I was thinking that washers would be too thick as .030 is only 0.8mm. I'II have another look tomorrow. |
Author: | 850man [ Wed May 12, 2010 11:34 am ] |
Any cylinder head shop should have hundreds of them, they have a proper name, I just remember what it is at the moment. |
Author: | mini_mad_matt [ Wed May 12, 2010 6:15 pm ] |
At work we have boxes of different sizes (just hardened washers), one particular size suits minis just fine. We also have a valve spring tester so we can work out what springs need how much etc. |
