It is currently Sat Jul 19, 2025 4:26 pm
PostPosted: Sat May 15, 2010 11:59 am
Greetings Mini Guru's.
I'm re-assembling the pedal box in my '64 Mini. About to re-spray it black. In my parts bucket I have a flat plate about 3 1/2" long. It was painted black. It has a hole each end (5/16") which are spaced 2 3/8" apart. The plate is shaped a bit like a drumstick (about an 1" wide one end, down to about 3/4" the other. I also have a long spring which could be related. Unfortunatly it's been a long time since stripping this project. Can't put a picture up. My e mail is :
[email protected]
Thanks
Alex.
PostPosted: Sat May 15, 2010 12:09 pm
Its not part 22 on this diagram is it?
 Post subject: What part is this
PostPosted: Sat May 15, 2010 12:18 pm
Mick
Thanks for reply. YES it is part 22 as per your diagram.
Well done. Is it somewhere under the bonnet? Could I have undone it to disconnect carby???
Alex.
PostPosted: Sat May 15, 2010 12:20 pm
:lol: Another mystery solved :D
PostPosted: Sat May 15, 2010 12:25 pm
Yes it is under the bonnet, it sits between the engine steady bar and the block. It pairs up with item 24 and 23 on either side of the engine steady rubber. Its the only drumstick shaped thing I could think of...mmmm drumstick...
I don't know about getting the carby off, but the engine steady does get in the way if you are trying to undo an exhaust clamp on a stock manifold.
PostPosted: Sat May 15, 2010 12:52 pm
thanks for that Mick
Alex
PostPosted: Sat May 15, 2010 1:45 pm
Hmmmmm..........when I put my engine steady back together I don't remember that bit - better check the bucket of 'spare' bits
David L
PostPosted: Sat May 15, 2010 4:04 pm
The Mini King
.Do not worry to Much
21 22 & 23 are used together, but If your car was fitted with 24 Then 22 & 23 are not used
PostPosted: Sat May 15, 2010 6:23 pm
Thanks John- I'll sleep tonight then :wink:
David L
PostPosted: Sat May 15, 2010 8:28 pm
that's wierd... my cars have always had 24 and 22 :?
PostPosted: Sun May 16, 2010 10:36 am
The Mini King
I may be WRONG, It has happened before. If I am a few other people appear to wrong as well Just a couple of examples http://www.minimania.com/web/CatPage/2- ... atalog.cfm
http://www.somerford-mini.co.uk/pdfs/Ca ... ntings.pdf
PostPosted: Sun May 16, 2010 2:50 pm
So I'm guessing the use of 24 removes the need for the spacer 23? If so I imagine the drawings just aren't very flattering for 21.
PostPosted: Sun May 16, 2010 3:05 pm
The Mini King
If You look at the bottom of drawing 21 and the top of drawing 24 it gives a little better idea of the difference in the brackets, The use of 24 negates the use of spacer
Users browsing this forum: drmini in aust, watsupskip and 79 guests
