rear wheel hub
https://www.ausmini.com/forums/viewtopic.php?f=2&t=63137
Author:  davestar62 [ Mon May 17, 2010 4:25 pm ]
Post subject:  rear wheel hub
gday everyone!
so i spent 3 hrs yesterday trying to remove the large nut (im not sure what it is called) holding the wheel hub to the rear axle! in the end, i had to cut the nut in half :evil:!!!!!!
so i was wondering if anyone knew what this nut was called, and if anyone knows where i can get a spare from?? i had a quick look on the minisport website, and only found them for disk brakes
cheers!!!
Author:  sgc [ Mon May 17, 2010 4:33 pm ]
Which side was it, driver's or passenger's? The passenger side is a left-hand thread, so if you were trying to undo it anti-clockwise, you were actually tightening it ;)
It's called a 'castellated nut', but you're best off trying to get one from a Mini specialist, especially if it's the passenger-side one. If you do find one at a bolt supply place, often the slots for the split pin are too shallow.
Author:  Hanra [ Mon May 17, 2010 4:33 pm ]
Is one side left hand thread?
Edit: to slow...
Author:  mini_mad_matt [ Mon May 17, 2010 6:09 pm ]
I'm sure every mini specialist will have one lying around. Phone them up and talk to them as its not something you would commonly list on the net.
