Trailing Arm Difference??
https://www.ausmini.com/forums/viewtopic.php?f=2&t=63188
Author:  Minimad [ Thu May 20, 2010 9:29 pm ]
Post subject:  Trailing Arm Difference??
Are the hydro rear trailing arms the same as the rubber cone arms??
Interchangeable??
Minimad
Author:  GT mowog [ Thu May 20, 2010 9:31 pm ]
No. They are different and not readily interchangable.
Author:  drmini in aust [ Thu May 20, 2010 9:32 pm ]
Nope the position of the knuckle is different, also the brake pipe setup is different, and hydro arms have a bump stop on top.
Also the handbrake bellcrank pivot setup is a bit different.
That said, it is possible to use hydro arms in a dry racecar with hi-los, according to Justminis.
Author:  Minimad [ Thu May 20, 2010 9:36 pm ]
Thanks.. Won't bother keeping them :o
Minimad
Author:  1071 [ Thu May 20, 2010 9:58 pm ]
As he said; a set of Hilos is all you need.
Cheers, Ian
Author:  justminis [ Fri May 21, 2010 7:12 am ]
Stub axle needs to be changed too, need a press, for the lower shock mount. Not the only way to do it tho.
Author:  drmini in aust [ Fri May 21, 2010 8:41 am ]
You can cut it off flush then drill and tap 3/8 UNF for a high tensile bolt. Works even better with Koni shocks (can then adjust em on the car).
