Gear selector steady bush on diff housing. https://www.ausmini.com/forums/viewtopic.php?f=2&t=63216 |
Author: | SuperCooper [ Sat May 22, 2010 9:48 pm ] |
Post subject: | Gear selector steady bush on diff housing. |
Is this bush easily drifted out? Needs replacing as its flogged out and causing some movement and bad gear changes. Have acces to a hoist which will make it easier , probably need to drop the LCB? Any info will help, Cheers! |
Author: | Mick [ Sat May 22, 2010 10:00 pm ] |
They are easily pushed in and out, but I've never done one while the engine was fitted in the car..doesn't mean it can't be done however. |
Author: | GT mowog [ Sat May 22, 2010 10:01 pm ] |
You mean the rubberised bush in a Rod Shift Box? I made up a puller from some 8mm threaded rod, a couple of nuts (one with the hx ground off it) and tube spacer. Use the same tool to install too. It works with engine in car and LCBs fitted ![]() I don't think it a good idea to drift it as there is not much meat here and there is a good chance you'll break the housing. |
Author: | Mick [ Sat May 22, 2010 10:02 pm ] |
Oh, I had my wires crossed, I thought you meant the bronze bushes in the gear selector on a remote shift diff housing..it must be late.. |
Author: | SuperCooper [ Sat May 22, 2010 10:12 pm ] |
On a rod change mechanism there is a shaft that is above and parrallel to the shift rod from the gearstick, and is secured to the top of the diff housing via a bracket , bolt and bush. So not the actual selector. It is this bush I am talking about. Hope that clears my mud. Thanks, Supercooper. |
Author: | Tombo [ Sat May 22, 2010 10:28 pm ] |
GT mowog wrote: You mean the rubberised bush in a Rod Shift Box?
I made up a puller from some 8mm threaded rod, a couple of nuts (one with the hx ground off it) and tube spacer. Use the same tool to install too. It works with engine in car and LCBs fitted ![]() I don't think it a good idea to drift it as there is not much meat here and there is a good chance you'll break the housing. I like what he said, a simple puller would be easy to make. Drifting it in/out would only work if the housing was supported properly which would be near impossible in-car. |
Author: | Kennomini [ Sat May 22, 2010 11:01 pm ] |
I tried replacing one once, I could only get the inner steel tube and most of the rubber out so I rolled up some tin until it was thick enough to replace what I had removed and slid that in. It worked fine ![]() |
Author: | drmini in aust [ Sat May 22, 2010 11:04 pm ] |
When a few I had rotted out I left the outer tube in place, they are a bloody tight fit. Then I turned up a polyurethane or steel bush to fit tight inside it. Steel works good- gets rid of the slack and doesn't seem to add vibrations either. |
Author: | mini_mad_matt [ Sun May 23, 2010 12:31 pm ] |
I saw garden hose used once, better then nothing i guess |
